willaduncan
    7
Everything posted by willaduncan
  1. Let's see the housing idea you have for it Sent from my iPhone using Tapatalk
  2. And the bracket that came with the lights is SHITTY Sent from my iPhone using Tapatalk
  3. I want something a little more professional then that, that's how you half ass shit. I will never mount anything else there at all. If I ever do an LED bar it will be on the handlebars. Sent from my iPhone using Tapatalk
  4. Jeff/Cody I'll take the lot of them at this price Sent from my iPhone using Tapatalk
  5. Not painted OEM, there is some white spray paint overspray on the fins but if you have fins you can swap or use a little paint remover it'll clean right up Sent from my iPhone using Tapatalk
  6. I'll do 30 plus cost of shipping Sent from my iPhone using Tapatalk
  7. Truly livin up to your new name!!!! Sent from my iPhone using Tapatalk
  8. - this is what the top/wider portion should look like, Inside width 1.883 Sent from my iPhone using Tapatalk
  9. I don't get it they are decent trail pipes seems you should atleast be able to make 100 bucks on em but it's not likely Sent from my iPhone using Tapatalk
  10. Tapatalk is messing up right now but the led mount is 1.883 so the opening of that portion needs to accept a 1.8825 bracket essentially a clamp on the top Sent from my iPhone using Tapatalk
  11. no the top part is an open bracket stand by I'll make a pic Sent from my iPhone using Tapatalk
  12. Take your pipe to mat shearer, he will fix that dent for cheap bro Sent from my iPhone using Tapatalk
  13. Sweet how fast can you do em? Sent from my iPhone using Tapatalk
  14. No thanks these lights cost me 18.50 plus a few bucks to make a bracket... Plus most LED stuff from China is just as good as anything else and costs about 20 - 40 bucks for a bar, I will be putting an 8 inch bar on the handle bars later Sent from my iPhone using Tapatalk
  15. Their new manufacturer isn't drilling all the way through there is a lip on them Sent from my iPhone using Tapatalk
  16. Good luck I had to practically give mine away Sent from my iPhone using Tapatalk
  17. Man motion pro is shitty... Every single adjuster bolt I have gotten from them lately has required reaming in order for the cable to go the damn thing, I called them and the rep said "they just switched their manufacturer and this has been happening a lot lately" seems like they need to find another new manufacturer Sent from my iPhone using Tapatalk
  18. Well it's about time y'all caught up with modern web design!!! Can't wait to check it out so I can order some new reeds from you! Sent from my iPhone using Tapatalk
  19. Ok aluminum how much can you make a raw set of these for corgster? Sent from my iPhone using Tapatalk
  20. Sorry for the crappy drawing I didn't have grid paper and I was in my truck Sent from my iPhone using Tapatalk
  21. This is my plan for the mounting I just need to find someone to build it for me, square stock mild steel to "fill" in the stock location with a brackets bent to accept the LEDs right above the location. Might get the actual measurements tonight and go to the local fab shop to see if they can build it. Sent from my iPhone using Tapatalk
  22. I do agree in order for this to be feasible you are gonna have to find a PB board that will work, mount all the electrical circuits on, make a housing to neatly store all the electronics. Seems like the price of yours after all the hours of labor and price of material will be in the $50 range ATLEAST Then to make money you will have to charge ~$55-60 bucks ... Sent from my iPhone using Tapatalk
  23. Podtronics? What happened to trail tech Sent from my iPhone using Tapatalk
  24. Question is can you put it in a housing to actually make it a practical application? Sent from my iPhone using Tapatalk
  25. That's what I was thinking but I would rather modify to fit.... Idk I might disassemble the housing today to see if I can cut into the housing to give clearance for the mount Sent from my iPhone using Tapatalk
