BAMF87
1 Follower
    Tucson AZ
    97 lollipop red frame, Vegas Jeff seat, works triple rates, alba gulfwing +2 aarms, HJR dune port, milled head, chariot reeds, keihin 28mm w/unipods, Fmf fattys, +4 timing.
Recent Profile Visitors
1,900 profile views
BAMF87's Achievements
HQ Soldier
HQ Soldier (2/5)
7
  1. Found this write up on jetting. I’m sure it’s been posted at some point but this is the best one I have read so far. It really helped me out. http://www.pilotodyssey.com/carbtuning.htm Sent from my iPhone using Tapatalk
  2. I’m having issues with my banshee bogging bad on 1st gear takeoffs. Once I hit higher rpms the bike will finally hit the power and and take off. What can I do to get rid of this bog Here is the setup. HJR dune port Stock welded crank Chariot head 19cc domes Chariot reeds Shearer inframes Keihin 28mm pwks 152 main 48 pilot N68A needle on middle clip Air screw 1 turn out Idle screw 2-1/2 from touching slides Carbs are synced No air leaks Elevation is 3500’ temp 80-90degrees Sent from my iPhone using Tapatalk
  3. True. Sent from my iPhone using Tapatalk
  4. worked for me, obviously you clean an wash afterwards Sent from my iPhone using Tapatalk
  5. Steel wool and some coca cola Sent from my iPhone using Tapatalk
  6. BAMF87
    Any duck hunters?
  7. BAMF87
    Hunting pics
    For you hunters on the HQ post up some pics of your kills. This is a feb 2013 south Texas whitetail This is a nov 2013 south Texas whitetail (already got this one on a pedestal) Few javelina bow kills Sent from my iPhone using Tapatalk
  8. Thank you Sent from my iPhone using Tapatalk
  9. Thx I just grabbed a few at ace I'll see what fits Sent from my iPhone using Tapatalk
  10. My local dealer has to order them and the other places that may have them are closed until Monday. I was going to get one at ace hardware I just need measurements Sent from my iPhone using Tapatalk
  11. Can someone tell me the length, and thickness of a stock flywheel key? I need one this weekend. Unless someone around tucson has one to sell me. Sent from my iPhone using Tapatalk
  12. Traded! Sent from my iPhone using Tapatalk
  13. Thanks hopefully I'll get it to glamis for Easter Sent from my iPhone using Tapatalk
  14. Few updates got it Rollin for now Sent from my iPhone using Tapatalk
  15. Pm sent Sent from my iPhone using Tapatalk
