ginger
    12
Everything posted by ginger
  1. i called waited 2 weeks and then ordered my swinger from JL. Im sure stellars stuff is really nice, but you can only wait so long.
  2. yes, its the part further to the front that looks bent
  3. looks like it had minimal oil or a bearing blow up
  4. which company would that be?
  5. next time instead of the water, keep turning the motor over so it sucks the flame back into the motor.
  6. PM me if you want to sell your triple rates to offset some cost, im interested in them
  7. not sure i never bent one my one shee i bent the frame the other i have aftermarket arms
  8. as long as its a A arm bike, and not J arm, (which you are good, J arms were late 80's very early 90's) they will swap.
  9. if you have piston slap, you may have a small piston for the bore size, pull it appart and check clearances to make sure there isnt an issue before it damages the cylinders/motor.
  10. a metal mesh screen would be fine, DO NOT USE PAPER, it will stop the oil to a degree limiting lubrication.
  11. the problem with this is that the wd-40 will break down the grease, making for less lubrication actually.
  12. travis, i have some but they need to be bored pretty bad from the previous owner. shoot me a text if you want
  13. bought a vegas jeff seat cover off of him, he took the time to pry the staples so it wouldnt rip the cover, and shipped it to me fast. great guy to deal with.
  14. definatly trans problems, i suggest stop riding and split the case
  15. the heat method works, just do it slow and easy, not to much pressure or too much heat.
  16. ginger
    frame
    do you still have the title off your old frame?
  17. from everything i have read, 100ll is not oxygenated. Also, depends on your gas provider, my local airport it is 108octane, im friends with the owner of the place.
  18. dont you know, canadian tires are square, watch southpark.
  19. i have in 4 stroke applications, but never on a 2 stroke app. if you do, you will definatly need to rejet
  20. i stripped the paint trust me there is nothing there
  21. my frame has no numbers, so im going to stamp my engine VIN into the frame to make it match.
