ginger
    12
Everything posted by ginger
  1. ^^ no one is going to help you if you cant provide correct information. you pilot is not 240. your main might be. your pilot might be 25 click on the link provided for your elevation, we arent going to do it for you.
  2. they might be good for a basic bolt on motor, just like how i wouldnt bolt shearers on a bone stock motor. but there are more powerful options out there.
  3. slides in the correct way? is the bowl with the choke circuit on the left side?
  4. normally i think people put a 27.5 pilot. and run the second from the top clip. but dont hold me to it. i havent played with stock carbs in prolly 4 or 5 years.
  5. pilot jet, or needle position most likely.
  6. clutch is out of adjustment then. you need to adjust the adjuster on the pressure plate.
  7. good luck finding one. why not buy a banshee and put the yellow plastics on?
  8. by advance you mean accelerate? When you shift does it rev up, but just doesnt go any faster?
  9. my SLP's cost the same as a new set of FMF's iirc
  10. if the motor is running the water pump is running. granted it isnt doing any actually cooling because you arent moving air through the radiator. so it can build heat depending on how long you let it sit there. you have to keep the quad moving to the air flow through the rad.
  11. i have never had one stretch to the point of that, normaly they rattle and kink up before they stretch that much.
  12. mine is still fairly fresh, but i dont ever really bottom out much.
  13. i have the sprocket and rotor guard from JDS, they work great. i dont run a frame skid, so i cant provide any feedback on them, i hate how much crap they hold
  14. while you are looking check that the bowls are on the right carbs, as that effects the choke circuit as well.
  15. in my mind SLP are like a drag pipe power wise, but the power comes in much lower.
  16. technology has improved and they are still the same. lol.
  17. there is a thread for this already somewhere on here. lol
  18. i never understood how people could run the stock swinger for so long. mine always got twisted out of alignment.
  19. check for a air leak with a leakdown tester.
  20. mines in the same spot. in reality its 2 bolts and 3 plugs and i can take the key, cdi, and voltage regulator out lol
  21. i know the feeling, consider yourself lucky. my old one got stolen and never saw again. Check with the forum sponsors here, they should get you a good price and be able to answer any details you need filled in.
  22. yamaha OEM stuff will cost more then good aftermarket. plus dealers dont know shit about banshee's
  23. i hate them, they cause the coils to rust because they hold in water. unless you never see water.
