thomas h.
Everything posted by thomas h.
  1. Doing dune port and case port Also pancake, B impeller, seals Removing 4mill spacer and installing 4ml domes Shift star and Yakkey shift drum Still considering tranny mods but it is a duner with mild hp
  2. I have 2005 Yfz 450 Stock foot pegs with heel guards. 45 Harness and ecu Bottom end. 135.00 Hubs 25 Stock steering stem 45 Plastic front and gas tank white 85 Gas tank. 45$ Pmr skid plate .250. 95$ Tmjlhesse@gmail.com text 760 855-4660
  3. Please post here and pm to help me keep track of questions
  4. Motor is @ HJR for port and stuff. I'll put on the chariot chain tensioner to help with the derail issue. Going with custome intake tube when the motor is back. I just need to sell my extra engine to pay for it.
  5. Great feedback and great build I'll looking to the chain part.
  6. Don't need the 450 fan and to be sure get a temp sticker to tell your engine temp. Try to get a swing arm that has a chain guide next to the rear sprocket. Wiring i used banshee harness and made my own lighting circuits. Sprockets are personal preference.
  7. I only go Monday thur Thursday maybe like a dozen rvs and out there maybe pass 6 people. Mostly helpful duner veterans that are willing to tow you home
  8. This is my spare motor kevin is doing the hole motor True and welded crank stock(by kevin) perfect cases low miles( no chain damage ) 0 miles top end 3rd bore(by kevin) all new seals and gaskets and inspection and put together (by kevin) this engine came from a 1997 banshee with all stock parts. it had seized because of no oil in gas. so when you buy it from me you can call kevin and tell him you want it ported for extra and the labor for assembaly is paid for. i dropped the engine off today and should be ready in 2 weeks or so. contact me here on bhq or tmjlhesse@gmail.com or text 760 855 4670 need 1,200 obo remember that kevin is still machining it right now.
  9. If you get a led whip(12v) and color match the under LEDs. Since its a part your going to you might have a six PAC cooler. setup the battery on the cooler or setup a removable battery.
  10. Don't go Yfz shocks unless you go all the way like Yfz arms conversion and relocated upper shock mount to get proper suspension cycle. My brother did the Yfz conversion and it does work and is cheap but if you don't relocate the upper shock mount or the lower a arm mount your ride hight will be two inches lower and your suspenision will not drop out. I.E. the shocks are at full extenion all the time like the springs need to be softer but then your ride hight will be even lower. Don't get me wrong the full conversion is way better than stock and the ride hight is ok. But real after market is better. The best would be long travel Yfz 450 frame conversion check my gallery for frame conversion pics
  11. Do you you think I could thread the shock body and resi? Would there be enough to thread? I hope not to have to weld nipples to it Or reposition the resi and weld I do want to keep it.
  12. I guess I'll just go for it. Hoped for someone with real shock knowledge to say it will not work But I think it is worth the risk.
  13. Part came quick and in condition as expected thank bro! Good communication
  14. thomas h.
    Need Crank
    Looking for a good stock or 4 mill crank trued and welded to finish my hjr build. *kevin is going to see what you sell me..
  15. hey got your message, I did the same converison. I also know of three in progress and about 6 already done. Also turns out that in england they have been doing this swap for road racing for years, some time they sell on ebay, also the BHQ has a frame converison area you could post up your build pics.
  16. A compass ( maybe not for a track ) A master link Spare levers and goggles Ibprofin
  17. My brother striped his out and a atv shop in Escondido ca called Yakkey racing charged 50.00 parts and labor for a heli coil install. We drove to pismo 20 mins later. Short for that you could chase it. Take the plug to a tool place and order the chase or the heli coil kit.
  18. I'm selIngl my plate to buy that style too. A mx racer told me the bling star dual design can pack full under the chain and destroy stuff. Im going for the single on eBay and which ever for the disk. I'll get one from a sponcer if they get on board.
  19. I did pm you but? Please send pics to tmjlhesse@gmail.com
