When Adjusting the essentric screw, put the bike it a gear, don't matter what one, first or second is good. Loosen up the lock nut, remove essentric screw, throw away the folding lock washer, install new one, check the end of the essentric screw for wear, if there are grooves replace. Install essentric screw. Adjust shifter claw so that there is the same amount of space between the claw and the shift star pin on both top and bottom. Double check. remove shift shaft, Tighten nut while holding screw with flat screw driver. install shift shaft to make sure you are still good, its good, remove shaft, fold washer replace shaft, install new clutch cover gasket. bolt everything up, refill coolant, refill with favorite flavor of oil. run the shit outta that shee!
Adam
will this help with cold lurching or having to rev it the put in first with out killing the motor. Or is this just for miss shifts?
Will pancake help?
