thomas h.
Everything posted by thomas h.
  1. 25 p 300m Stock needles So maybe screw in the mix screws Btw choke on doesn't help New motor too
  2. Also check spark plug caps. Look for ngk rubber boots and non resistor plugs. Tors unplugged?
  3. Seems like if I don't use it for 2 months it need alittle spray to get it going. Why and is their a fix. Stock motor t5 and k&n Good plugs and caps
  4. Cool, and I really like that JD is willing to try new stuff out.
  5. Again my cheap works shocks and +3 fireball arms are 7.87 times better than the 450 arms.
  6. 2 1/8 inches relocated Also move the shock away from a arm when you weld the new tabs.
  7. This gets about 11 frame to ground New tie rods about 13 9/16 length He has the yfz450 spindel too And under the extra dust caps are washers The springs are all the way soft and it's alittle harsh. I would also get 1 inch wheel spacers.
  8. If you do it you have to move the lower shock mount up and in to get the ride hight corrected. I helped my brother do it and now he saving for real arms because it just isn't right. But he had them for two seasons. But it is much better than stock Pm your info and ill get you some pics
  9. Shearer pipes let your motor spin to 10k+ You will need a pro mod tranny to shift it
  10. I guess it only does pass twice so... Dual pass works too
  11. I run W wetter or water. And I really have not got the ride it longer than 15m at a time. I hope next week I get to run it.
  12. Don't use the after market pipe mounts. Stick with the factory rubber mounts to keep them from cracking off the mount tabs. Also shearer sells raw pipes to other suppliers and those suppliers are using lower grade chrome or nickel also clean your chrome with proper stuff
  13. Besides the dealer ship or used, most of the arms that use bushings don't send new one they expect your to use your own.
  14. Yup. The inlets are on the same side and there is a divider between them. That make the water go by twice. The core is two row and I'm adding a top shroud to the radiator to ram more air in to radiator. Should be testing in glamis next sat with 95* weather.
  15. Can I see some radiator pics please. I'm interested in where the smaller water line goes in to the system.
  16. I like the sleeper 4 mill idea. Also less leaks and better than spacer
  17. Do builders cut 2 mm out of a stock head to clear the 4mm crank? I picked up a shee last week and it was advertised a 400cc by alba but it didn't have the plate. It had no port and 310 jets and the pistons are coated in carbon because the jetting was rich. I can't read the top of pistons with video scope. Any other way to check besides tearing it down? I put 290 mains and its good now
  18. Do you think he's compensating for something ? J/k it's just 2" wider than most
