SKEETER
BOOBS
    121
Everything posted by SKEETER
  1. That's sexist of you to assume it's a "he"...
  2. Definately done by a Floridian ^^^^
  3. Or you could do something kinda silly......and have who's porting your cyls, match the pistons !?
  4. Transfer #s are more important than intake
  5. Just depends on your area. In Oregon probably 1 out of 10 have ethanol free premium. Call around, see who's closest.
  6. Non ethanol premium would be ideal. You dont need race fuel.
  7. Pull stator cover off, the timing plate is behind stator, you'll see #s if aftermarket and advance able, stock might be notched holes to get +4 timing
  8. South Texas banshee has a video how-to . Check it out
  9. Need to figure out what domes in the cool head, and/or do a proper compression test. Unless its ported, with higher compression, no need to mix race gas. Non ethanol fuel is a good idea however.
  10. Subframe removable ? You can Google raptor frame in 4 seconds, and know your answer~
  11. How much psi are you losing total?
  12. Redline 4mm dune port , 175psi, stock modded carbs, t5s, was 75hp , probably my favorite engine setup for playing. You can get everything you need under your budget, call and talk to cam @Redline Racing tell him your budget, and he'll shoot ya straight.
  13. If you're capable of tearing engine down, sending parts off , you could build a 70-75hp/ish 4mm. Send cyls off for porting, head,domes, tors delete on carbs, clutch, misc parts.
  14. Well, to start with, I'd imagine knowing what carb you have would help tremendously..
  15. What's your max budget for engine. And is it bone stock? Carbs, intakes, head, pipes , etc
  16. If your having cam do the porting, call and see if hes got some already.
  17. My 4mm cub with 39pwks, shearers,185psi, ran 50pilots,158 mains, cel needle, middle clip. 0-1000' elev-
