SKEETER
BOOBS
    121
Everything posted by SKEETER
  1. I got 700 cash and 200 worth of food stamps to offer
  2. It makes your serval, have a cub top end. With a lil thingy that opens/closes the exhaust height.
  3. Yes. Theres a post on Facebook bhq about it.
  4. Highly doubt that ^^^ loose as a goose
  5. Speaking of....Raspberry zingers are da bomb .
  6. IMHO , you need to post this on Facebook bhq. That's where the clues are.
  7. Fact. Nobody from Florida has shit to talk, about any orygun folk.
  8. Figured that'd get your attention. ha
  9. Most guys I know use insulation you buy at home depot .
  10. Run it then. Wont be any louder than rest of the fellers at windy bay
  11. If you can, get the old piece out, measure length and diameter. Report back.
  12. You need to figure out what your port timings are on cylinders. Compression. Timing. Etc. Multiple pipes that work good for drag. Shearer,cpi,led. Where will you be racing ? Dirt /sand track , dunes, hill, ?
  13. So did someone with a clue do a drag port on the cyls? Not knowing any specifics on the motor setup is hard to tell what you'll need. Strictly drags, you might as well run alcohol. 35-39mm alky Carbs, intakes, filters, used will run 300-600. You'll need better pipes, about 300-500 used. Post pics of bike so we can see what'll need changed chassis wise.
  14. Factory banshee carbs, that have been t.o.r.s. deleted, drilled. But if your actually gonna be drag racing mostly, a bigger set of carbs will be better option. Either way, that single carb is holding you back big time. Who built the motor, ported, etc. ? If we know what's actually done to it, itll be alot easier to get you setup for drag.
  15. Side note, you could probably trade that 2-1 setup/carb to someone for a pair of modded stock carbs, intakes, filters . And itll run better , and jetting will be a ton easier for you.
  16. If you think that was negative, you're on the wrong forum pal
  17. SKEETER
    Pingel
    Might hit up Brian eoff @ west coast ATV parts. On Facebook, or here.
  18. Heres your sign~ ~ bill engvall
  19. It's not a drag bike. With a single carb.
  20. Do you have a driveline stealth head?
