Surfrjag
    4
Everything posted by Surfrjag
  1. Surfrjag
    wtb tailight
    yes, did you get my pm a few days ago? still looking
  2. Surfrjag
    wtb tailight
    Looking for a 3 wire tailight with brackets. Thanks
  3. I beleive thats the actual size in inches. adding timing usually needs more fuel. If your timing is set low then adding will help some with your richness. I dont think you have any plug reading with the gas n go technique adopted by randy. Haha
  4. How is a dune ported motor not enough for trail riding?
  5. I think you can go 1 turn open from cloaed on the pj. Make a pass and check the plus. Did you ever see where timing is set? Out on airscrew leans it, no more than 3 turns and then go to smaller pilot. remember what your builder said! Haha
  6. It will fit in banshee carrier 03+ is direct swap the 02 and older needs the brake hub
  7. taking the lid off more than likely made it run lean so a jetting change will be needed. if you have the stock filter it is held in place with the lid so you can either cut a bunch of holes in the lid or replace it with a clamp on filter. I ride a lot of muddy/dusty trails so I use a foam filter in the stock box. we need to know what domes and jetting you have now to help.
  8. im looking for these few parts to get this motor together. everything missing besides shift shaft and shiftrod I need. thanks!
  9. base gaskets are cheap to...
  10. lets see a pic of what you did to the flywheel
  11. how about a list of what you do have? maybe even prices? I know that's asking a lot..
  12. so if its just leaking cant you take it apart use some sealant and try it again? or is it ripped?
  13. big bore vs small bore pic yours look like big bore. good seller guys!
  14. willing to sell me a upper left a arm?
  15. I used some radiator hose from auto parts store, cut it and clamp it. do your silencers slide into the pipe at all? that joint shouldn't see a lot of flex to begin with I wouldn't think.
  16. that doesn't make sence im looking into it...
