Surfrjag
    4
Everything posted by Surfrjag
  1. All oem ignition components?
  2. Sorry but I did compare to a 35mm pwk. Fyi
  3. Cubs like timing I run them +6 on race gas all the time
  4. Each bike is different so before changing jetting I would check squish and needle. Check pickup gap and new plugs gapped. Then try again. Any idea what base gasket?
  5. The needles are marked right near the clip. The 2 cubs I just tuned both wanted 160 mains. Anything bigger was a big loss in power. Did you check squish? Bump the timing at least and try again.
  6. Go to +6 timing and 160 main 110 straight not mixed Do you have a lockout?
  7. Timing? Compression? 170 is probably rich too
  8. you can do it with the carbs off. same as wot
  9. Use a magnet Look behind the basket there is an oil deflecor peice of metal. It can catch a nut
  10. Pretty sure brake stays are the same on both 35 and 40mm carriers
  11. So what did he tell you.. We want the whole story
  12. I have some you can have if you can wait a week
  13. No I wouldnt. A new clutch can do the same thing if t sits Did you search google there are multiple places to download it
  14. If its been sitting sometimes the clutch plates will stick together. Take it out so when u put it in gear your ready to go. It should go away..
  15. Looking for some polished 10x2 with 18" smooth buffs
