Surfrjag
    4
Everything posted by Surfrjag
  1. Yfz shocks ride like poopoo. If all your trying to do is lower it some blaster shocks are much cheaper and ride like poo as well. Rm stators crap out, you can google that one and see multiple testimonials to their junkness.
  2. Your buying a bunch of jets you may or may not even need. If it even has the ones you need at all...
  3. There is a dyno near chesapeake guy is cheap and will jet it right on.. only gwt the jets you need
  4. So if you need a 27.5 pilot and a 300 main.... then what Where are u from I go to busco all the time
  5. You need to trench them if you go with that crank...
  6. There is no best for everyone ratio to run. You need to test and see what works for you and your setup.
  7. Haha let me know I want flames shootn out too
  8. Yes or frayed tips of pedals. Could try swapping them
  9. Check your reeds, swap your pkug wires, new plugs. Report back
  10. Turbo chassis I bug him all the time and he still makes me quality parts.
  11. Lean... Air leak likely or improper jetting or clogged pilot jet
  12. Is it sucking bowls dry? Pingle valve or plugged vent cap?
  13. 1 cc wont make a big enough power difference to risk separating that crank and detonating that topend. Get the port work done and true and weld that crank!
  14. Right but if its .060" squish now then that might be your problem. Like if its set up for a .012 base and has a .020 instead. It wont have the torq to get out of the hole like your describing. You dont know till you check...
  15. http://www.acerracing.com/ball_bearings/3/16_Ceramic_Silicon_Nitride_Balls-1191-65.html http://m.ebay.com/itm/380211578612?_mwBanner=1
  16. 152? Did you check squish? Whats wrong with more timing?
  17. You can find a ceramic ball. I think its 3/16
  18. Clutch is smaller with smaller rod and ball and they dont make one that im aware of
