possum
    6
Everything posted by possum
  1. nice.. id be interested in the 10dm if i didnt recently get a 10cub. looks like a deal. also looks like the parts i bought were still on the list? or u didnt remove them?
  2. im assuming its the side idle screw and the lower one is the air screw. ok for tge air screw go all the way in lightly then 1 turn out. and for the idle screw, tighten till it lifts the slide a lil. thats the starting point. then start the bike and adjust from there
  3. thats if it wasnt jetted right but if it was. start at middle clip. 1-2 turns out. and play with it from there
  4. the air screw and needle adjustment adjust off of the jetting itself. although air screw will be 1-2 turns out with proper pilot. and needle u can start in the middle.. then fine tune later.. go read up on how to jet first
  5. on a serious note. pjs are tempermental on the pilot. try dropping it down. if it wont start when hot. could be jetting or electrical. timing is possible. change the easy stuff first then move on to the next to find the problem.
  6. wow u are stupid dodger. u cant seriously think thats what im seriously doing.
  7. what motor did u switch back camatv 535 cheetah or 465 cub? where did u notice power loss? can u give info on ur setup if u can. dome config, porting, comp, pipes etc thanks
  8. yes daj see how ur all stalker status and flustered. and just start making things up to try and make it all tie together like u know what happened. = trolled u aint gotta be so mad that i have mat shearer. and ur still looking foward to get a hjr motor.. hahahaha
  9. daj ur getting trolled so hard u dont even know it! lmao
  10. Real worl experience dont count here. You need credentials
  11. haha phelps u posted while i was typing.. same idea i said
  12. maybe lean. bump up the mains a size or two. since u say ur lean at wot u probably are lean at 1/2-3/4 also. u could raise the needle to see if that helps. then if it does, but not enough go up on main jet.
  13. thats why i asked. he would know more then anyone else. im listening
  14. i just want to know what one of the top builders in the country recommends and why.
  15. actually i kinda liked reading cattledogs post about old sleds. that was a lil much green. and i like both u guys to. no homo
