possum
    6
Everything posted by possum
  1. I have a feeling Hjr got a lil phone call from someone. Then bam, you get a refund.
  2. possum
    Spindles
    Good stock spindles on the cheap. Gonna modify them.
  3. Crank seals are fine. I like to put them back in the same way tho. They will usually have a lil mark on the rubber where the case halves meet. Rotate it back to that spot. Thats what I do never had a problem.
  4. Your chasing your tail. Unless you like to waste more time and money, go for it. New crank, new domes, done.
  5. I need 4. The factory M10x1.25 lock nuts fits 14mm socket.
  6. I think a stock banshee with fmfs will suffice.
  7. Anybody got any extra ones in good shape. Before I buy new.
  8. Some builders dont even understand how a tz dont make any sense without straight cuts. Sure you can do it, but is it right.
  9. Yea like hp says. Cruising around, looking to get into the baddest dunes around. While trying not to get lost. GLAMIS If you want some duning, and best drag hill with the fastest bikes around. but not huge like glamis. Super easy access, with still a good amount of dunes. DUMONT
  10. You want to lean the metering rods on lectrons till it gets a lil pingy coming back down to idle. And rev off idle should be real snappy. Also the metering rods are never exact either. So I have one longer then the other.
  11. Id run front buffs in the front. And some sort of v paddle. +4
  12. possum
    Marvins wanted
    13.5" rear 12"fronts
  13. I already found one. But what are you asking. Might want another
  14. If you plan on beating it up. Use some sort of rattle can. Id suggest satin, semi gloss. It will touch up better and easier. Clear coat will look better but be harder to fix. And automotive paint will also be harder to fix to look good. My painted frames last me forever with no chips, scratches, etc.. but I just ride dunes and I take care of my bike.
  15. I use a cutoff wheel. But im good with it. I use it all the time
  16. Steel braided brKe lines are like 30 bucks on ebay brand new
  17. I didnt know people still rode banshees without a pancake.
  18. Actually driveline sells there domes on ebay. And they are rather nice domes. But I know what your sayin Radar.
