possum
    6
Everything posted by possum
  1. Slower, since we have talked a couple times about this. I believed in a 1st gear start. So I tried this on hillshooting. My experience is that it dosent really work optimal for my setup or possibly hillshooting in general. This is my findings. At 10,000 rpm with stock primarys and 22" tires. A 17-41 gearing with 1st -4th is 38.4 mph 52 mph 63 mph 75.6 mph A 15-43 gearing with 2nd-5th is 44 mph 53 mph 63.6 mph 76 mph As you can see to have the proper hill speed with both setups. Being 1-4 1st gear is extremely short. Then the next 2 shifts are very close. So its basically the same spread except on the first shift. I have tried both, and even at 44 mph wheel speed out of 2nd it still seems a tad short but pulls through the gears good. Now with the 1st gear 38 mph wheel speed it felt like i had to shift 5' out from the launch. Now if you bump the gearing up to match coming out of the hole..1-4 18-38 gearing with 1st - 4th is 44 mph 59.6 mph 72 mph 84.6 mph Now with that tall of gearing to come out at the same speed look at the spread on all shifts now. And on the hill you will never pull that 84.6 mph 4th gear. Unless of course you have a 150 hp 85 tq motor. I can pull the 3rd gear at the 72 mph but its to short at the top. Not to mention the falling off the pipe on a shift to soon or something. Note: I have tried all these various combos and a few others on the hill. And these are my findings. Hope that can help somebody.
  2. dunable override and be done with it. just pull your clutch in when slowing down. Simple
  3. wheredahoesat, I got some old odd sized ones ill never use. I have already drilled some but pm me. i might have 6-8 mains.
  4. check rockymountainatv they have a wide selection at good prices.
  5. You usually have the step on the dome cut deeper to compensate for the stick out. In order to get the squish correct. I had to do the same thing.
  6. Where did your port timing end up? how far are you out the hole?
  7. What you got goin on there J-Madd that your piston sticks out?
  8. If it was me I would ditch the 17's. And run less compression and run more timing.
  9. id like to know what different trans gearing he has.
  10. No Finch, I wont be going. Honestly Im not driving 12 hours and spend $1000 in fuel to go up there. Only way I go is I tag along with someone.
  11. Rollout? And are the wheels powdered, spray canned or?
  12. This movie really made me love banshees. And said im gonna get one and fly like those bikes one day.
  13. Who remembers Sandsation vol.1 on vhs? This was the greatest movie ever at the time. I wanna say early-mid 90's it came out. I watched this movie over and over for years.
  14. where you getting the bearings and seals? I need a set
  15. Which 6 different brands?
  16. I did a custom setup as well with the stock shock. Works very nice.
