possum
    6
Everything posted by possum
  1. matt, your not dragging so why not just stick with a stock modded?
  2. mike im wondering if your spindle / tierod setup is making it worse then it should be. just thinkin out loud.
  3. Slower, I see people having all 6 hd springs and around 8-10 grams each arm. What do you you think of that? Whats the reason or benefit?
  4. I duned my 1-5 with 100 hp all day no problems. you just have to ride it properly
  5. possum
    1/8 set up
    Even with tire spin out of the hole you still managed a reasonable 60' and e.t. and mph for the first time there just to see what happen. Good job last night Capizzi.
  6. Skat trak is in calimesa. They will buff any tire to super lite. And add paddles however desired. But those are skats not Stu
  7. If you want fast you got the wrong cylinder. end of story.
  8. Cut off the links in the way and connect a master. 1 link shorter should still fit easily.
  9. Its real stringy and sticky and dries really fast. I didnt like it. I dont like 1211 either tho. I went back to grey permatex.
  10. ive had many of both versions with 6 or 7 slides in either one.
  11. possum
    1/8 set up
    Oh I see. Not questioning you or mat. Just trying to have it all make sense. What springs did you hsve in there at that time?
  12. There is a reason Redline uses and sells alot of cpi and its not because they are better then shearers. Fact
  13. I got some inframes perfect for that serval. pm me
  14. possum
    gear change
    Dont you have 20" tires?
  15. possum
    1/8 set up
    oh I was under the impression that slower has and recommends similar clutch setups for both surfaces. And mike you had a ton of weight for the sand 27g per arm.
  16. possum
    1/8 set up
    I had all heavy duty springs(i know... i dont know base pressure, but they were the stiffest springs ive felt)). Along with 9 grams on each arm. On a 10cub. Good? bad?
  17. I had 165 lbs with 18 cc domes stock cylinder 198 130 durations.
