bansheemandan
Everything posted by bansheemandan
  1. $3800 or trade for a 2006 and up yfz450 2001 banshee, with title, the quad was just built from the ground up and only has 2 hours ride time since it was finished, it is very fast, i just want to try out a 4-stroke chassis --- (again everything on the banshee only has 2 hours ride time) powder coated frame-a-arms-front and rear hubs-swingarm-steering stem-spindles-foot pegs-rear brake pedal extended lonestar a-arms extended durablue axle// the axle is adjustable and you can make it wider rear shock rebuilt and revalved by RRP yfz front shocks rebuilt by RRP every bearing and bushing in the chassis is new new chain and sprockets new front and rear brakes new rear brake caliper rear stainless steel brake line renthal handle bars new rear tires//gbc gators new front tires//razr's RAD dual bearing billet aluminum axle carrier PRM front bumper PRM rear bumper PRM swing arm skid plate PRM chassis skid plate polished alum. master cylinder cover polished alum. throttle cover polished alum. handle bar clamp/ key holder new throttle and clutch cables like new yellow plastics carbon fiber hood/radiator cover shock covers headlight covers black and yellow gripper seat cover IMS oversized gas tank i am sure there is some stuff that i forgot about engine (again only 2 hours of ride time) completly rebuilt bottom and top end 4 millimeter stroker crank with tz bearings/trued and welded HERR JUGGS RACING ported cylinders HERR JUGGS RACING cut stroker domes PRO DESIGN cool head WISECO pistons and rings CHAROLET reed cages and carbon fiber reeds KEIHIN 28mm pwk carbs K&N air filter with outerwears cover WISECO clutch basket BARRNET clutch TOOMEY t-5 pipes and silancers PRO DESIGN high flow water pump impeller all new seals and gaskets throughout engine PRO DESIGN timing plate
  2. trade for a 2006 and up yfz450 2001 banshee, the quad was just built from the ground up and only has 2 hours ride time since it was finished, it is very fast, i just want to try out a 4-stroke chassis --- (again everything on the banshee only has 2 hours ride time) powder coated frame-a-arms-front and rear hubs-swingarm-steering stem-spindles-foot pegs-rear brake pedal extended lonestar a-arms extended durablue axle// the axle is adjustable and you can make it wider rear shock rebuilt and revalved by RRP yfz front shocks rebuilt by RRP every bearing and bushing in the chassis is new new chain and sprockets new front and rear brakes new rear brake caliper rear stainless steel brake line renthal handle bars new rear tires//gbc gators new front tires//razr's RAD dual bearing billet aluminum axle carrier PRM front bumper PRM rear bumper PRM swing arm skid plate PRM chassis skid plate polished alum. master cylinder cover polished alum. throttle cover polished alum. handle bar clamp/ key holder new throttle and clutch cables like new yellow plastics carbon fiber hood/radiator cover shock covers headlight covers black and yellow gripper seat cover IMS oversized gas tank i am sure there is some stuff that i forgot about engine (again only 2 hours of ride time) completly rebuilt bottom and top end 4 millimeter stroker crank with tz bearings/trued and welded HERR JUGGS RACING ported cylinders HERR JUGGS RACING cut stroker domes PRO DESIGN cool head WISECO pistons and rings CHAROLET reed cages and carbon fiber reeds KEIHIN 28mm pwk carbs K&N air filter with outerwears cover WISECO clutch basket BARRNET clutch TOOMEY t-5 pipes and silancers PRO DESIGN high flow water pump impeller all new seals and gaskets throughout engine PRO DESIGN timing plate
  3. still never sent them back,,,, that is because there is nothing wrong with them, he tried getting them for free, sellers beware
  4. i am still waiting for him to return them so i can give him a refund
  5. i typed it wrong, it is a 38mm pwk air striker, not a 39mm
  6. 39mm kiehin pwk cark $100 shipped i can email pictures
  7. wanted durablue eliminator posi lock for banshee
  8. i told him to send them back and i will refund his money, i never heard from him since, go figure
  9. ok, keep them then, make up your mind, i have a 5 year old that is smarter then you
  10. i have a stock crank for sale, i just bought it from NYUK, it is in perfect condition, i just decided to go with a stroker crank instead $125 shipped red hood/radiator cover $25 shipped yellow hood/radiator cover $20 shipped yellow gas tank cover $20 shipped 21cc pro design cool head domes $30 shipped stock gas tank (no petcock) $25 shipped coolant overflow bottle $15 shipped rear brake rotor $20 shipped brand new stator cover gasket (still in wrapper) $15 shipped stock carbs w/tors and cable $50 shipped stock axle nuts $9 shipped pm me your email address for pictures
  11. look, you must not no what you are doing, you have another post asking about what mods to do to them to get them to work with your intakes, if they were so screwed up then you should not of installed them, send them back to the address that is on the box they were mailed in, i am not going to piss around with you
  12. bullshit, i forgot to send 1 of the pressure plates with them, he clearly stated that he put bigger screws in them and ran them for 2 hours, he could not wait until the pressure plate got to him, if they were so fucked up my even install them, he should of pm'ed me right away, before installing them, how do i know he did not crack them putting bigger screws into them
  13. i also have spindals with brake rotors and calipers and brake lines --- make offer a-arms -- make offer 38mm keihin pj carb (needs choke $30 new) $65 front shocks $50 gas tank with fuel pet cock $50 good stock crank $75
  14. i bought a crank from Infamous039, it was just as he described it, and super fast shipping, a+++ seller
  15. mop and glow floor wax give plastics that new shine, put 3 to 4 wet coats on with a soft rag, also for white stress marks use a heat gun on them, brings the color right back
  16. honda 250r parts for sale pro design cool head $100 tcs dome for cool head (new) $75 keihin 39mm pwk carb $75 upp intake boot for 38 to 39 mm carb $40 i can email pictures
  17. it does not matter, i did not send my cylinders out yet
  18. looking for a 4 mil spacer plate or 21cc 4 mil cut domes for a cool head
