tipn22
About tipn22
  • Birthday 08/26/1988
    Mt angel oregon
    98 stock banshee
tipn22's Achievements
  1. ok so i finally got my jetting right in my carbs its was the needle jet i had it 2nd from the top when it should have been in the middle like it comes stock and it runs good bottom to top end so now all i have to do is change my pilot to a 27.5 or a 30 cause it run best with the air screw half turn out the needle jet being off by just one spot made my bike run like shit on the bottom end no power till i got some rpms going
  2. thanks i'll try that and do a plug chop when i am in Florence this week end
  3. ok i think im getting some where now im going to put the stock jet back in ,i already tried the needle at the lowest point and my fastest idle is after 2.5 turns out and its better but a slight hesitation still so the stock jet should do the trick .i just found out 50;1 is richer than 40;1 in fuel to air mixture
  4. ok i just ran my bike with 320 mains and 27.5 pilots its run amazing mid range and top end but might have been rich ,but the bottom end bogs right off the go and adjusting the air screw didnt seem to do much for the bog , and when i pull the choke it dies so what should i do go bigger on the piolts , or smaller on the main jets, run a 50:1 mix or do all three ???? not really sure but your help would be great
  5. [quote name='tipn22' timestamp='1312868161' post='1258400' dual k&n pods power pro pipes im at 300 feet about 70 degrees out side .and those are the only mods and running 40:1 gas mix
  6. i dont know to much about jetting but i guess i'll do 300 mains and 30 pilots
  7. could you tell what size of jets you were using for your power pro pipe i got some and need help i all so got dual pods and that about it if you can help that would be grate thanks
  8. i have my banshee jetted for my k&n filters witch is 220 main jets but what size should i go to for my power pro pipes im at 300 feet about 70 degrees out side .and those are the only mods
  9. they look like the power pros i just got
  10. i had called, pj motorspots about a few items that he said he might have to order, but he would call me back and sure enough about an hour later, he calls me back after hours and tells me he has my parts in his hand, that was really great service he went outta his way to get my parts by the dead line that i had witch was today when i got the parts, witch were all genuine mikuni, pj motorsports is looking out for you, find them on the sponsors page
  11. http://portland.craigslist.org/clc/mcy/2294203555.html
  12. ok turn your (air screw ) out slowly tell you get the fastest idle if it is less then one turn from closed you need a bigger pilot like a 27.5
