OK, you want help? I'll give you help. You don't need the yellow and black headlight wires to make it run. There. You do need a known good BANSHEE CDI, a tested good stator, a tested good Banshee coil, wires connected PROPERLY between them. Scotchlocks do not make a proper connection. Wires twisted together and taped do not make a proper connection. They need to be soldered and heatshrinked. Butt connectors are a step above scotchlocks, but still should only be used for car stereos and things that won't leave you stranded in the middle of nowhere. From there, you're going to have to trace out the white/red to brown trailer light connector wire through the trailer wire connector and back to the white/red CDI wire, etc. and make sure all the necessary ground wires are connected together properly. If you can do all that, then you ARE good at wiring. Go to it.
I wasn't being an asshhole. I was just pointing out that the junk wiring you have is going to cause you problems FOREVER, if you ever get it running. I AM good with wiring and and even I wouldn't try to salvage that mess.
