blubyyou
blubyyou last won the day on October 15 2022
blubyyou had the most liked content!
1 Follower
About blubyyou
  • Birthday 03/13/1982
    West Virginia
    03 banshee 4mill HJR dune/play port- Pro Circuit pipes- NOSS head 21cc domes- Chariot intake w/Boysen reeds- PWK 35 AirStrykers- ProFlow/ K&N- +4* timing- pancake bearing- modded shift star- Tusk clutch 3 HD springs- Chariot water pump- CAMATV cut transmission. Laeger +2 +1 arms- Ace Fabrication swing arm- Lonestar axle- Elka triple rates w/ rezzies up front- TCS dual rate rear- YFZ 450 calipers- AC bumpers- AC propegs- PEP stearing stabilizer- ProTaper bars.
Recent Profile Visitors
2,899 profile views
blubyyou's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. Looking for a nice, clean flywheel. No rattles...working 100 %. Pm me a price shipped and a pic if possible. Thanks.
  2. My favorite is Klotz flex drive, and Klotz super techniplate @ 40:1. 50/50 green antifreeze. It is a little pricey and there are some more budget minded combos that will definitely work as well. Just my personal preference. I used to run 927...but the Klotz seems a little cleaner burning to me.
  3. Also a possibility the key that lock the flywheel not seated correctly? After all it did start initially for a minute or two...next day no such luck. I mean this thing is dead ...it won't even pop. The motor is a fresh, low hour motor from HJR that I assembled. Maybe less than 5 hours on it just dialing it in while on the other frame before I swapped out frames.
  4. So I swapped everything over to a new frame....even started it one time real quick. Then I added XFR propeg nerfs ....no start. I was thinking maybe the nerfs were not allowing a full kick so I took them off....still no start. I run a key switch under the seat, pro-design teather, lights off the factory kill/ light switch, and full harness. TORS has been unplugged and removed on my 4mil motor w/pwk 35's. Checked stator resistance at the plug ...ignition coil side within spec, pickup coil within spec, lighting coil barely out of spec @ .4-5 ohms. Checked primary coil spade to spade...barely out of spec @ .4 ohms ( should be .28-.38 ohms). Tried to read secondary coil from plug cap to plug cap with no reading...same exact thing with another coil I had laying around. I did drop the flywheel when I put it on for the initial fire up but it ran once....weird. I also noticed that one lug on the flywheel was a little taller than the other affecting the pickup coil gap....hmm? But it ran well before. I have not pulled the stator cover again...possibly a bad flywheel, pickup coil/ gap, cdi? Im starting to get a little frustrated and puzzled with it. Where would you all start to look? I've been ripping my xp 900 all summer and would like to get the banshee going again before the end of summer. Thanks
  5. Interested in cdi, stator, coil, complete wiring harness, flywheel if you still have it. Pm me a price and some pics if you don't mind. I'm looking for an uncut harness. Thanks.
  6. I replaced my ac bumper with an alba....looks good and not a bad price. I think I paid 70 or so.
  7. Well I just finished my build and it won't start. Long story short I removed my cut harness, cdi, coil, stator...was running just fine. Put on a new uncut harness, cdi, coil, and stator with all the plugs and wires....I wanted to run lights this time. It started up initially...then I welded on a couple of tabs for my xrf propeg nerf bars to mount to. Went to start it and it won't hit a lick. I think I messed up by welding with a mig and not unhooking any of the electrical stuff....I know, my stupidity. Next question is where do I start? Buy a new cdi, coil, and stator? Just want to get it running. Thanks.
  8. Need two rear hubs shipped to me by Friday. Splines are trashed on mine. Please pm me asap ....PayPal ready to send. Need new style bolt pattern....
  9. I need the rectangle end plugs off the front lights ....I thought I needed the new triangle style but I don't. Don't need the entire light ...just the rectangle end plug and a few inches of wire to splice my new lights to. Please pm me with what you have. Thanks.
  10. broken stock headlights....new style plug...02+. Looking for the end plugs off the headlights. So I realy don't care if the lights are trashed. I'm installing new lights and don't want to spice into a new harness. Let me know what you have. Like I said, I don't care if the lights are broke...just cut off the end plugs, sell me that and keep shipping cheap. Thanks.
