I have had this problem ever since I got my shee a few years ago. I got it in a trade not running, replaced the stator (not oem, but it has been going strong and I have tried another stator with no change) and then it would run on both cylinders. It had a nasty mid end "bog" that I figured was a jetting issue. After trying messing with the jetting on the stock carbs with no difference, I switched to a single 34mm keihin pj carb with exciter intake manifold. It did the exact same thing even after messing with the jetting on that carb as well. After that I figured it was because it had 85psi compression and probably wore out reeds. This past weekend I just got the bike back together after putting in a 4 mil crank and some mildy ported cylinders for it along with brand new reeds from TDR. After doing my heat cycles, I go to take it out and it does the same exact thing except now it is basically unrideable. Before, I could just clutch it and could ride it just fine. With my new setup it seemed to just exaggerate this flat spot. Basically low-mid rpms, you hit this rpm where it will not get past it. It doesn't matter if you vary the throttle, it just is stuck in the same rpm. If you clutch it, you can sometimes get past that stage and it will rev out. I have switched literally everything on this bike from when I get it except the cdi and coil. That leads me to believe it is one of those. It feels like the timing just goes wack and that prevents the rpms from going anywhere, but I have never heard of that. Also, I leak down tested it before and after the rebuild and it holds 6 lbs for 6 minutes so there are no airleaks and I do know how to jet a bike so it is not that. If it helps this is my exact setup: Redline Racing 4 mil play port, 65mm wiseco 795 pistons, hot rods crank, 20cc domes with cool head, single 34mm pj, fmf fatty pipes with stock silencers, Tony Doukas modified reeds. Thanks
