thrill-billy85
3 Followers
About thrill-billy85
  • Birthday 03/18/1985
    Garden City, KS
Contact Methods
  • Yahoo
    aklein3185@yahoo.com
    99' Man-shee FAST dune port Wiseco pro-lites HotRods trued/welded crank cool-head 20cc domes vforce 2's R-2 pipes +4 timing 28mm PWK's w/ uni pods chariot huge impeller oversize radiator 450 front susp. conv. silicon hoses piaa lights 1 1/8 bars, and risers moose grille seat by VegasJeff various polished shit (carbs, dogbone, throttle cover)
Recent Profile Visitors
3,034 profile views
thrill-billy85's Achievements
HQ Soldier
HQ Soldier (2/5)
3
  1. Ahh so much to do here. First thing is a good compression check, next, visually check spark, and ensure the bowls are on the correct carbs. Could also be a dirty pilot circuit. The screw you're talking about (pilot) is actually called the air screw. It meters air in the pilot circuit
  2. Well he had to buy a crank anyhow. I thought the biggest spacer you could run was 2 mm? Hes gonna have to make up for an addl 9mm of total stroke?
  3. Helping out a friend with his banshee. He ordered a 4 mil long rod crank (against my advice) its not been ported, and will not be any time soon. Question is- whats needed in the way of piston choices, and possibly spacer plates (il advised I KNOW). Custom milled head?
  4. Its a small block, i assume. He cant tell me much about it, and ive got zero experience with these. Any differences on the outside to look for?? Root- is it timing plate, flywheel, stator, pickup, cdi, and ignition?.... cause we'd need all that
  5. Yeah. Hes got a 6 mil with the same setup. What he doesnt have is a pvl flywheel puller, tdc dial indicator, etc.
  6. Also.... before when it had the lectrons(alky), he had a guy try to set them up to run gas. They were able to get it running, and rode it a bit though it ran like total shit. It running like shit was due to improper carb set up. That issue is solved. Now, out of nowhere the ignition is going haywire. The ignition worked fine before, with no changes since, now something is going bad. Ive read something about some half moons? They can go bad, and theyre essentially like the pickup coil? Thatd cause BOTH ignition coils to not fire? Correct?
  7. We gave it pretty good kicks. I even took one for the team and stuck my pinky in the boot, to see if itd shock me..... i didnt take one for the team needless to say. Lemme ask yall this.... why will it spark, and run the motor when it is cold, but then die after a minute of running, and not sparj thereafter. Its done this twice.
  8. So a friend of mine recently got a 10mil twister cylinder banshee. Got it.converted back to gas today with some 38PWKs. Started right up, reved and idled fine (2 minutes).... then..... died. And wouldnt start. Checked the spark.... nothing... in either hole. It has a PVL ignition system which i am completely unfamiliar with. Any idears? We were able to start it before the carb swap, and it did the SAME thing. Started, reved okay (wrong carbs) and suddenly died, and wouldnt start.
  9. Your crank bearings are done. The closed plug gap is from your piston kissing it on the up-stroke. Good luck man
  10. I am gonna go with an airleak. Still got the boost bottle?
  11. Yeah i didnt silicone them. Its a pretty jank way to do it. The owner of the bike got plowed by a friend, who, "knew what he was doing" Anyways, i need to track down some new boots for 35mm carbs. Any ideas
  12. Can anyone tell me what kind of manifolds these are, and where i can get new boots?
