Pat the one the only
1 Follower
  • Interests
    three wheelers, two stroke dirtbikes and quads and just about anything off road.
    93 banshee, boost bottle, yfz450 shocks, purple bars, racing front fender, powdercoated frame, 25 pilot jets 200 main jets, tors removed.
Recent Profile Visitors
Pat the one the only's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. No, 125-135 is what a brand new motor has depending on altitude, you are probobly thinking of the compression of a banshee with a cool head with about a 20cc dome.
  2. Damn, i miss the banshee gotta get another one..
  3. no it almost blew the 2 into 1 PIPE off the cylinders, and i found it was a bad coil connection, i fixxed it, rejetted, and boy this hauls for an almost stock shee lol
  4. hmm, i replaced the bad cap, and it still backfires, but VIOLENTLY!, it blew smoke through the airbox, and moved the 2 into 1 which was tightened down hardm almost off the cylinders! its pissing me off, do you think its a cdi? also if i get one, i noticed alba made a nice one with a switch on it to switch ignition maps.... anyways i dont want to waste money if it isnt it tho, any other ideas?
  5. everythings good, except maybee i had a plug cap go bad, cause we switched one that was falling apart...
  6. my throttle slides are opperating smothely, clean filter, perfect reeds, parking brake switch and tors system including box are removed, and the stator was tested while it was mounted, so im stumped
  7. my problem isnt with fuel, or compression if it idles perfectly, so it must be electrical, but my stator tested perfectly, could it still be bad? or is it the coil or cdi? if the coil went wouldnt it have no spark? it has fat spark, and idles fine, but doesnt wanna rev
  8. my banshee is a 1993, with a stock coil, stator of unknown origin (may be stock), and a vitos cdi box. the TORS, parking brake, TORS box, and taillight have all been removed from it, so no issues there, i just took out both reed blocks, saw no cracks so i double checked the tightness, then cleaned both carbs perfectly, put a new choke tube on, and cleaned the air filter. the shee will now kick start and idle perfect, but when i try to rev it cuts out, backfires, and almost sounds like its running on one cylinder, but its hard to tell with a 2 into 1, hmmmm please help me out here guys
  9. lol always a wise ass nah, that pic is like 6 monthes old during the rebuild
  10. i lost mine too when i split the cases, the yamaha ones are deff the way to go, and theyre mad cheap just remember to put them in perfectly strait or youlle have problems, oh put a lil loctite around them to mine are still holding tight.
  11. my banshee is a 1993, with a stock coil, stator of unknown origin (may be stock), and a vitos cdi box. the TORS, parking brake, TORS box, and taillight have all been removed from it, so no issues there, i just took out both reed blocks, saw no cracks so i double checked the tightness, then cleaned both carbs perfectly, put a new choke tube on, and cleaned the air filter. the shee will now kick start and idle perfect, but when i try to rev it cuts out, backfires, and almost sounds like its running on one cylinder, but its hard to tell with a 2 into 1, hmmmm please help me out here guys
  12. i used an ohm meter to check the stator and using clymer's specs it was perfectly in tune, there are no specs out there for testing a banshee cdi however, and i have no buddys with extra cdi's. i pop started it, and it would idle like a champ, but would cut out and occasionaly backfire on rev up, any ideas? im thinking cdi or fuel
  13. i checked and i didnt shear a key, i have fat spark, and the plugs are good
  14. maybe, but i dont hear any odd noises when i turn it over, this is a puzzler..
  15. hmm im deff going to check both tommorow, any other possibilitys?
