coryv4
Everything posted by coryv4
  1. its because my shifter wasnt adjusted right
  2. i got mine from m&m cuz fast was on a 2 week back order on the cylinders think of it this way 421 cubs make alot of topend power just move the 421 cub power down the rpm range and you have the serval i raced my cuzins 450 and i beat him at half throttle because i couldnt shift past half throttle think my shift isnt adjusted right
  3. if you have the money get the serval i havnt got mine fine tuned yet but it still has amazing power i am running stock carbs but i am going to get 35mm IMO its woth the cash
  4. on my 4mil it has +4 stamped on the inside of the crank right next to the rod pin
  5. just did you a favor i called the guy on the 88 its either stolen or the guys retard GUY:its got the cool heads new piston think its been bore has them toomey racing exhaust i think k&n filters with the nylon sand screens works shocks and he said he doesnt no much about it he took it off his buddys hands......
  6. they look like my t3s wich had the shortest power band ive ever seen it cam on at just under wot and pulled like a raped ape for about 2 seconds
  7. maybe its just gearing i mean any bike will bog with to high of gearing
  8. lol i just skimmed across it i think the main might be rich or 2 short of filters not getting enough air?
  9. could it also be do to the fact that it was 103 and it wass running rich?high humidity?
  10. did u run your port job before you baught the 18s?
  11. i think it might be a spark issue or maybe dirty filter?
  12. first off ive heard the rad valves accually make less hp maybe you running a lil rich on the main stator might be going bad it could be a number of things give some more info whats ur compression and hows ur plugs look
  13. get a 421 serval all i have to say is im never going back to a 350 again best investment ive made on this banshee
  14. i am running 400s in my stock carbs
  15. unless the head is milled just run premium 93oct
  16. i think you were really really high when you did ur speed run with my 22s and a 15/41 gearing and my trusty Gps i only did 84
  17. i run 15/40 in trails with my 421 serval if i run anything higher i cant control it
  18. they are pretty much a cub with factory look
  19. that cant be right get another compression tester i am running 23cc domes and i have 145psi and i am also in michigan at 700ft
  20. put a 27.5 in there put the clip 1 down from the middle and keep the main the only thing that will really happen if ur rich is it will be really dogy it wont really hurt the motor on my 421 serval with stock carbs i am running a 27.5 bottom clip needle and a 400main and it seems about right
  21. just to toss out an idea i am getting my whole frame a arms and swinger with candy blue ice and white plastic. almost all colors go with black IMO
  22. i used a grinder with a cutoff wheel it was meesy but cleand right up with a fine file
