toytech
toytech last won the day on September 11 2013
toytech had the most liked content!
1 Follower
About toytech
  • Birthday 06/13/1963
    midland michigan
  • Interests
    riding atvs scuba diving rc cars
    2000 blue banshee, mx front suspension,40 over bore,4mill crank,coolhead, 35mm carbs, fmf pipes and silencers -1 inch swing arm,maxxis tires,douglas wheels. it's bored 40 over, v force reeds, 4mill crank 110 mill rods, vito's power pistons, with cool head and cut domes no spacer, 195 compresion on both cyl's, ports are cleaned up and matched, 35 mill round slide carbs not sure on jet size, k$n 8" pod filters, fmf fatty gold pipes with turbine core silencers, one peice intake with internal crossover, +4 timing, 15 42 gears 20" razor tires,
toytech's Achievements
HQ Soldier
HQ Soldier (2/5)
20
  1. I bought 1 because thats all the shop had and we wanted to ride. 2 days at the dunes it was toast. never again
  2. air leak. did you do a leak down test?
  3. get the scew kit, it has everything you need. Fast Racing has them.
  4. very good, great guys to deal with. Jeff has done work for me on 2 motors. very pleased with both of them.
  5. you need to find someone that can weld it.
  6. all around. that way 1st gear isn't useless. I have a1 through 5 duneable trans.
  7. we have 1 from Fast and 1 from HJR both work great, and take backloading, we trail ride to. 3 seasons on 1, 2 on the other.
  8. post #3 I run 16-41 on my dune shee
  9. I have the extended lever in an older yamaha thumb throttle, no tors crap on it, think its from a 3wheeler, I is very easy push no thumb fatige.
  10. if you unbolt the caliper put an extra pad in it and hold it up higher then the master it will bleed out better.
  11. junk. Racetech electric. they are a site sponcer.
  12. I like mine on my dune ported 4mil. clutch grabs much better.
  13. unless its an all out drag bike I would not make it any narrower. too unstable.
