ZillaFreak
    56
Everything posted by ZillaFreak
  1. They look like NGK caps, do they not say that on the top?
  2. your plugs are very dirty, if that dirty, just think of the cylinders.
  3. This is a major issue with people. No one fucking reads. The ad clearly says OEM gears
  4. Just saw the invertor, I was thinking rectifier. An invertor takes DC and converts it to AC. Might mean the voltages is 12VDC and converts it to 90-130VAC. So on a banshee, you would need a rectifier to convert the banshee's 12VAC to 12VDC then the invertor converts it back to AC.
  5. The listing is just shit. It says power supply is 12VDC. Then says voltage 90-130VAC. Find out from them what they actually work on.
  6. Looking at the ad, says it runs on 90-130VAC. This sounds like it is going a house outlet. A banshee puts our around 9-13VAC, a tenth of the ratings. If you are looking at how to run them, clear zip ties.
  7. IIRC, the shearer silencer tube goes over the cap, at least the one that is apart in my house does. Plus it had some meat to the cap.
  8. With a hex bolt, what do you expect the threads of the bolt to grip?
  9. Read up on both. http://www.klotzlube.com/techsheets/KL-104 Tech Sheet.pdf http://www.klotzlube.com/techsheets/KL-100 Tech Sheet.pdf
  10. Looking good. Going with black rivets or SS?
  11. Modded shift star is nice. No need to replace the detent arm. Check eccentric screw. Check the kicker and rebuild if rattling. Check seal and bearing for clutch push lever. Check water pump assembly. Pancake bearing should be installed. Also check clutch cable.
  12. Not only can you not read, but you are also stupid. I didn't bitch, I posted a rule. The people bitching are you, steve, triple chin, about me. I posted the rule to inform the guy. He cried like a lazy bitch because posting prices is too much work. Then all all you bitches starting to bitch about me posting the rule. So, how am I the only one bitching?
  13. So is posting a simple rule really that bad? Didn't know this site had some many bitches. Answer this question, how hard is it to post up some prices and pictures? How hard is it to read, well for you it seems to be very hard.
  14. Why, because I posted a rule? Didn't figure you for being a little bitch? What has ruin this site is dumb ass people that can't communicate, ei form an eligible thought or read.
  15. So rules don't matter to anyone? What is the point of have rules, simple rules, if no one has to follow them? All I did post the rule about prices and the seller got butthurt like all the other crybabies.
  16. Very lazy. Can't post pictures, can't post up some prices for the main items. Not a big loss.
  17. 3. Prices are mandatory! This is not eBay or an auction. Failure to post a price will result in deletion of your post.
  18. ya, i am just wanting to see actual picture to see which design they are reselling.
  19. Can you post a picture of the T9 exhaust? On the website, it shows shearer pipes, another it shows toomey t5 pipes. http://www.skylineperformanceae.com/t9-exhaust-for-banshee-350
  20. You know anyone that has done this? Thinking what is the best route for the hoses with doing this.
  21. Been talked about. Didn't K+T post a video of them doing port work and porting the water jackets to get more/better flow into them?
