BANSHEE HP
HQ Site Sponsor!
    10
Everything posted by BANSHEE HP
  1. explain "eating up 4 pick up coils" a little better. i run a pvl, ive never had a problem a pickup or igniton coil going bad. curious is all
  2. heres my personal favorite all around paddle tire...
  3. call either shearer or rdz and get the story from one of the horses mouths
  4. adult owned never raced not for beginers 100mph+
  5. if these carbs were on a snowmobile theres no way they could be gravity fed. quite a few of us in the shout box told you these were pumpers. im not sure you know what we were talking about by removing the seat, you can press or beat them out but they are not meant to me removed.
  6. gotcha, hope everything turns out good for you
  7. i may be alittle late to this but isnt this the motor in question? http://bansheehq.com/forums/index.php?showtopic=149077&st=0&p=1286438&fromsearch=1entry1286438
  8. ftz is junk, wicked motorsports is no better. get some shearer custom pipes
  9. 32:1 use klotz super techniplate oil, ive never used a case saver but they wont hurt anything, distilled water and or 50/50 anti freeze, depends on mods and carb setup. pm me since ur local with some of the finer details.
  10. "Very Dirty in pic But i will take 475 Shipped for both side" bet you would... stator cover from cascade 250 NEW water pump cover cascade 60 NEW clutch insert 25 NEW mirror polish a stock clutch cover 95 from cascade $430 + a stock clutch cover
  11. turbine cores have the spark arrestor and the forestry approved stamp on them. youll be able to get in no problem.
  12. id use a shop rag of some kind to stop the gears over a screw driver.
  13. take better up close pictures of the cylinder walls, more then likely itll need plating but... gotta see what they look like.
  14. you dont bore a cub cylinder you have it nikasil plated, it will aways be 68mm. you send the cyilnder off to millenium technologies 1404 Pilgrim Road • Plymouth WI 53073 phone: 920-893-5595. they replate the cylinder and send it back to looking brand new, get new set of 68mm pistons and your done. edit: wiseco 573mo6800 is the piston part number you need
  15. pretty sure its an old street bike triple.
  16. because the phone would just ring and ring and ring. i think northwest sleeve has them.
  17. bump for a good p.c. crank cant get um no more
  18. the hemi head II will accept noss,modquad, pro design,chariot the older orignal two piece hemi heads had 2 tabs to lock the dome in position, grinding one of those tabs off the head allows the same domes to be used.
  19. better bring a boat or jet ski for the january 20-22 dates
  20. if there was sand in the intakes, then theres no possible way the pistons are fine... theyll be a dull grey color. rings, bearings, pistons and cylinder walls all would be affected if sand/dirt makes it through the filters.
