BANSHEE HP
HQ Site Sponsor!
    10
Everything posted by BANSHEE HP
  1. if im there I bet I can get 7hp out of each piston.
  2. 513, 795, and these new pistons are all 13°, just different pin heights and intake window shape/location. Basically the new stroker pistons have a blaster pin height so moved up 6mm from stock but are in stock through .080" bores. Where blaster pistons don't start until .080 over.
  3. go to silverlake forum and read about the voucher lines. you could roll into town tonight and not get vouchers for 4th of july. its a fuckin madhouse Friday mourning 3-7am holiday weekends
  4. so you fixed your problem? trying to run 8 plates on a Mattoon basket with driveline lock up and unmachined inner clutch hub? 7 plate and the driveline lock up will hold north of 120hp without using the stiffest springs or all the balls.
  5. best plan of attack is to get tehre thursday night or before 5am friday. bring food, t/p and beer. they say you cant start lining up before 6am but itll be a mad house(like any holiday weekend) from about 3am till 5 or 6 when the cops start letting you get in line. then the line moves at 12 or 1230. getting the best possible spot in line is about the most important thing youll do over the weekend.
  6. thanks for the offer but im looking for uncoated cases.
  7. BANSHEE HP
    stock cases
    clean as can be stock cases wanted. no chain whack no repairs. Clues needed also.
  8. 54mm is stock. 64 would be a 10mm+ stroker. but its not likely that's what you have. take some pictures and report back.
  9. As far as the rings having .50 on the top means it's .5mm over sized also .020". You'll have to inspect the piston further to find out what rings you need or if new pistons and boring is in your future.
  10. 29L is the oem 110 mm rod. 29L/R is the denny wang junk 115 mm rod
  11. get chu' some. up to 18t on the fronts and 38-45t rears
  12. Do yours leak or are you just asking a board question?
  13. Vitos has the 68mm pistons your looking for. They are not made by wiseco but are for the cub.
  14. These are a new piston option for 4 mm long rod cranks with stock cylinders. The intake windows are in the correct place for the stroke. The pin offset is the same as a blaster piston which is 6mm higher than stk banshee pistons. These are made in 64-66mm no 68's. They are a 13° dome profile like stk banshee pistons.
  15. ive got a degree in FFS and this is a bonafied level 5 FFS
  16. just so we can get a starting point: it ran with all Thomas's electronics after the rebuild. stopped running, I figured it was the flywheel what was rattling like crazy. Thomas bought a new after market one from motor city atv. wasn't the flywheel, as there was still no spark. gave him a older style stock stator in good shape. bike runs with it installed and the new after market flywheel. a few days later, now something else is wrong.
