BANSHEE HP
HQ Site Sponsor!
    10
Everything posted by BANSHEE HP
  1. vitos has a piston with the same specs.
  2. anyone got a weight on stock, chormoly , and ti stems? just stems not with bars
  3. naw, ziggy used to make aluminum stems.
  4. base gasket thickness, cylinder height, stroke, rod, piston
  5. maybe make a pipe, then test it and then if it actually works then name it
  6. atv cycle and sport is his shop and they are in L.V.
  7. Too close to Mexico, would not ride.
  8. You can buy new orings, and they can be put on with out breaking
  9. too bad boating season is over, might have better luck selling anchors in the spring
  10. oh, the domes that stone sent in with the motor are the same ones he got back, but re-cut (rough as fuck as i said). now when you cut a stock stroke dome and make it into a stroker dome, you of course cut the step of the dome deeper and the chamber deeper (to keep it simple). now what happens when you make those cuts and screw a spark plug in?... the spark plugs hangs into the dome chamber 3-4 threads worth. Now ive cut domes like this for myself, before have the cnc available to make blanks and domes however they need be, and you must run copper washers under the plugs so when screwed in they sit flush with the chamber. stone was charged $75 for new domes, not to re cut the same domes and fuck them up in the process.
  11. I wouldnt call and apologize to eca. The domes i took out of stones motor were some of the worst cuts ive seen, chatter marks from the cutter, the squish band and chamber are as rough as running your finger nail over a fine tooth comb, not to mention the .035/.036'' squish with 8.5mm wide band. The porting.... the intakes are clean and even (but over done imo), the exhausts are very aggressive in size and shape and not the same from L to R cylinder. I still have to toss numbers around and figure out what could be done to make them run to there potential. but at very least he would need new domes cut.
  12. It's beer thirty in my town, when I clock in tomorrow I plan on looking at the numbers I wrote down. But yes the domes were less than what I would call ideal.
  13. Ill stick with what I said. I just met up with stone and checked out his motor. Nice guy, just doesn't know his way around everything yet but is willing to learn and understand what's what and why it is what is.
  14. might as well not post them. the intake means nothing.... looking at ports with out measuring means nothing... saying you only got 60hp means nothing....for less than $10 in beer ill measure and inspect what you have now and youll then have a clue to what youve got and what your next move is going to be.
  15. do you want someone that has a clue to look at it?
  16. Cam, up here its my buddy racing. "My buddy said" is the line that you hear most. My buddy builds alcohol drag sleds, well your buddy doesn't know fuck all about a stock banshee.
