n2otoofast4u
    218
Everything posted by n2otoofast4u
  1. Assuming you live in Havasu? What's the setup on the bike? Mods, carbs, jetting, etc. Its cold as F down there right now, so whatever you do now will be a bit different when it warms up a bit.
  2. And is your name Brock? Or did you misspell "broke"? Where are you from? FL, PA, MI, or NJ?
  3. Didn't read all of it. That said, is the choke tube on?
  4. I never had an issue with galling with a raw JJ&A.
  5. Be prepared to beat that fuck outta that hub to get it off every time! I had one for 1 race and it galled so fkn bad it was ridiculous. Promptly took that thing off and went to a JJ&A.....
  6. Back the bolts out past the split. Put a penny in the split and snug the bolt up again the penny to separate the hub just a bit. Remove.
  7. Mark this on your calendar! For the first time ever Skeeter is correct! Get the carbs right before you do anything else.
  8. Punch, cover so it doesn't get PCd over, move along with your life.
  9. You may need machine work for your new build. You don't get that with the "kit".
  10. What's the temperature outside? I'd pull the carbs apart, probably something stuck in the pilot. I'm a 27.5 pilot guy on about anything that's in that low of elevation, particularly if it's cold out. Some will say your mods aren't going to warrant the 27.5s, but they always worked well on the junk I was around.
  11. Mods? Elevation? Carb specs? Does it have reasonably similar compression in both cylinders?
  12. Still available? Sorry bub I had to. And FOCK a RZR! Can Am Max is the way to roll!
  13. You've pissed away 60 hours on a model to tell you that water will flow in one side, and out the other???? Claudia........ these are outdated shit boxes! Put down the mouse, turn off the computer, and go find some pussy!
  14. Here's reality 1- Get some Splinter looking Cali to OR transplant fuck involved. 2- Get a janitor from Canada involved 3- Change the head gasket, but block shit off to redirect water that's been making the same path without issue for 30 fkn years. 4- Report results
