n2otoofast4u
    218
Everything posted by n2otoofast4u
  1. You're sure it's not air locked, and is circulating water well?
  2. If the bracket is tight on the carrier how do you suppose you are going to rotate the carrier to tighten/loosen the chain?
  3. Start asking for Geoff, Orlando, Arlo, Brad and Whitehurst.... Kick every one of them in the dick!
  4. Dry engine, use starting fluid....... noted
  5. So he's to loosen the plugs... Why?He's to spray starting fluid where? On the now loose plugs? If it's not getting fuel, why not fix the fuel problem? Your suggestion was dumb as fuck, thus creating my hypothesis.
  6. 2 things. 1- It says the location in the add 2- If you're serious you would call him. Don't kick tires!
  7. 1/4ips if I remember correctly. You will want brass flush plugs.
  8. Are you talking the threaded holes in the bottom of the cylinder?
  9. This guy is dumb as fuck! DO NOT DO THAT! Start reading, keep reading, and then read some more. Then come back and ask educated questions.
  10. Fill with diesel. Run in neutral for 3 min. Drain. Repeat 3 times. Fill with oil of choice. Go ride.
  11. "Had no oil. Made whine noise. Now fucked. What's wrong" UN.......FUCKING......... REAL
  12. UT is tuff to make HP. If you have a G to spend get ahold of a site sponsor (Redline or WK) and tell them your budget and needs.
  13. Take that 460, find someone with a large boat, and gift it to them for use as an anchor.
  14. I like the old one. At least she came on here and talked to us!
  15. Good used works sell for under 500 and are a VAST improvement over stock. Everyone wants the best shit but 90% don't ride hard enough to need it. Works will be fine.
