n2otoofast4u
    218
Everything posted by n2otoofast4u
  1. In the 4 stroke bike world, I would absolutely say FBG is the place to call. HOWEVER, this is 2 stroke banshee world and nobody knows them in this industry like Packard does.
  2. If the lectrons are NEW setup by Packard then the lectrons will be fine, if they are old and have had 4 other people fucking with them, either send them to Packard, or throw them in the garbage and have a builder set you up a set of PWKs. Used PWKs are a gamble because you never know what someone else has drilled them to.
  3. I wouldnt buy pistons until you have a builder look at your cylds to be sure they are within spec for bore size and shape. 9 outta 10 times just because it runs on that bore doesnt mean that the cyld is within spec. Also. DITCH THAT EBAY BUYING BS.... You might save 3 dollars over what a builder on here charges (Often the builders are cheaper than ebay) but the time to build a relationship with a builder is now. Eventually you are gonna need them and theres no time like the present to start building a relationship with them. Ebay wont give you advise, tunning info, or answer the phone if the part you got is wrong.
  4. Sand the inside of the new cup where the isolator goes, then heat the rod to good and warm and freeze the isolator. They be sure they are both parallel with each other when going in.
  5. Thanks.. And yes this is a screaming deal. I just dont need a door stop so I have no need to keep them.
  6. Well, if he was 10 and wanted your fucking blaster shit he would be on blasterhq....If you know it wont help then why do you even mention it? Fucking MORON!!! As for the jackazz that started this thread, this isnt bansheewelfarehq...... If you cant afford the parts then you cant afford the sport! Put you money in better places!
  7. If you dont know about it, and the owner dont know about it DONT BUY IT
  8. Dont listen to these clown... DO IT! Thing would be badass, and ultra fast.. Heck it 600cc! It will smoke everything.
  9. "Like a good neighbor..............." Best way to keep all wories away! However, if you feel the need to lock shit up inside your garage, Id really look into moving. If you are that worried about something of such little value how the fuck do you keep your wife and kids safe?
  10. Tick? Like the rattle sound? If you have roasted that many parts and havent found the cause you might want to. They wont fix themselves. Oh, and I sur ehope your motor assembley is better than your silencer mounting.
  11. Luckily for you one of the top builders is right in your back yard so when time comes for parts or to go faster you have just a short drive to Redline. Welcome to bhq.
  12. take airbox and toss it on the trash. put on 2 pods with outerwears and move on..
  13. IMO I would richen it up on the bottom and see what happens
  14. There are a few options. I know there wont be enough to helicoil but is there enough room to drill and tap to the next size and then drill your head holes to the larger studs? Are there any threads left or are they totaly ripped out? Sometimes you can buy good new studs, clean the holes really good, and cement new studs in and then be sure not to over tighten them. The factory tourqe spec isnt really all that tight. Welding the holes might actually cause more harm than good. There are however some good epoxies that are capable of being tapped if all else fails it might be worth it to look into this option as well.
  15. I have a brand new set of Mattoon billet cases that I bought for a project and have since decided to use a different setup. They are currently setup for 64stroke and are for a small bearing Crank and have the fork window in them. Right now they are patterned for a DM but for 100 bucks more I will ship them to Mattoon and have them patterned to a DMX. Cases are brand new never had a Crank in them. $1500 shipped in the 48.
  16. F that leak down bs. If you put the motor together correct I'd skip that. Sounds to me that its a low end lean issue. It doesnt matter what your Mains are, if the bike is too lean to get up in rpm and need the main then they will never play a factor. Being that it will run correct on choke tells me its lean on bottom. Where are your needles set? what happens on a dry rev if you hit the throttle while its idling?
  17. Ive heard they do awesome work. Do they make monsters bigger than a 421?
  18. 10,000 sperm and you were the fastest??? Just proves that not all droolers and helmet wearing fucks can be taken care of with a lack of gag reflexes or a coat hanger.... Move on you retarded faggot.. No need for you here!!
  19. This is the same clown that was telling me I have no clue about building bikes, and all the while hes wanting a pat on the back for installing a homo sticker kit on his plastics... He knows little to nothing to say the least.
  20. 421cc??? That is HUGE!!! Who do you buy that from?
  21. Im sure this will help get your shit faster... I hope he sends your money back in a sack full of dog shit...
