n2otoofast4u
    218
Everything posted by n2otoofast4u
  1. I can assure you there will be more people at the dyno day that have crashed my junk than I have!
  2. well, well, well...... Look who it is! Cory, this will fuel RR even more! www.raptorhq.com
  3. So you paid on the 22nd (Tuesday) so that day dont count for shit anyways. He ships in on Monday the 28th. So he shipped it within 3 business days of you actually sending him the money and your bitching? Get fucking real. Your complaint will come with ZERO cares... Get lost
  4. So do you have 2 names? Are you fucking stupid? This "guy" (who is either you or your boyfriend) has ZERO idea of wtf he has, zero idea of wtf hes doing, and then you are playing second fiddle who knows just more then the other "guy".. For fuck sakes, hes got big bore out of frame drag pipes on a fucking 421 serval. Although I dont agree with everything Cam comes up with, I would venture to guess he forgot more than you know.. Good luck getting ANY help from people on here now.
  5. ALL STARTED BY THE SAME PERSON.... First on the 28th (day after he joined), latest was yesterday. And asked the same question TWICE! http://bansheehq.com/forums/index.php?showtopic=163192&hl= http://bansheehq.com/forums/index.php?showtopic=163200&hl= http://bansheehq.com/forums/index.php?showtopic=163217&hl= http://bansheehq.com/forums/index.php?showtopic=163222&hl= http://bansheehq.com/forums/index.php?showtopic=163218&hl= http://bansheehq.com/forums/index.php?showtopic=163302&hl= http://bansheehq.com/forums/index.php?showtopic=163219&hl= http://bansheehq.com/forums/index.php?showtopic=163298&hl=
  6. Trinity owns the rights to those cylds. If you are wanting a new one, it will either come from them, or through them.
  7. Whatever they are, they are no bargain at 400 bucks!
  8. Cooling? Are you not running this at a high rate of speed in frigid temps? With that much air movement and with the temp differential so high, there's no way you can convince me that with a good radiator there's going to be heat issues.
  9. Are you certain you have a good ground? If you just PCd the frame you will need to grind off the PC and make sure you have a good ground on your coil and motor.
  10. They aren't that bad to open up. A bit intimidating but when you get into it you will find they aren't that bad. Did you do a comp check or how do you know it lost compression? If you did that means it will turn over which is a bonus! Its hard to tell from the pics but the plug top looks speckled from deto but its hard to tell. Its not uncommon if its detoing to have the strap close up like that. Its there fresh "whack" marks or fresh "specs" of aulm on the plug?
  11. Box gap plugs are fine. If your running forced induction then gapping them is needed. If your running NA pull them from the box and install them in the bike.
  12. WAY less expensive, more power, less heat, and its cooler to say it runs on alky than it is to say it runs on gas.
  13. But it was 3 bucks cheaper from the other guy... DUH....
  14. serval, alky, drag........ This motor seems confused of its sexuality.
  15. the CK-158 rod is a 115mm long rod....just as redline said
  16. The crank will most likely work. The cases will have to modded not only for the bore but the different rear stud location and cyld size. IMO the 39s will work fine, after that there isnt much that you have that will transfer. Your looking at cyld, head, domes, hardware, intake, reeds, pipes, and Id assume that you will need some additional stuff on the clutch side depending on how quality of a build your 465 is.
