thbanshee81
    indiana
    04 black and red... its new so it just has the t5s on it an jeted
thbanshee81's Achievements
  1. I will check it when I get off work.. Ill let ya kno if that's it.. Thanx man I never thought bout that
  2. its one carb running richer than the other.. if them not being synced exact doesnt have anything to do with it than thats fine.. i just wanna kno why one is richer than the other
  3. thats what i thought. they should be pretty close. im stumped
  4. coolants good, smoke is normal smoke, and yea ive tested the spark an its good an blue, would the carbs not being synced make it run richer?
  5. no just eyeballed but they were pretty close... the card not being synced run richer than the other?
  6. making sure the carb slide move at exacly the same time *there are srews on top of the carbs to adjust both. theres a good video on youtube showing u how to do it
  7. making sure the carb slide move at exacly the same thing there are srews on top of the carbs to adjust both. theres a good video on youtube showing u how to do it
  8. i synced them after i cleaned them real good so as far as i know they should still be good. ill check tho.. would that make that side run that much richer
  9. My banshee is running great but my ride side pipe is smoking more than the other. the right spark plug fouls everynow and the and the left side is perfect. i was wondering if anybody else has had this problem with the right side being richer than the other. my airscrews are both the same. i was wondering if the clip on the needle could be adjusted to be different than the other carb? i would just like some input if someone else has had this problem. my mods are just piped and jetted its an 04 with pretty low hours
  10. when i start it to warm it up or when i let it idle an it loads up a little bit my right pipe always smokes a little bit more then the other. is this a problem or easy fix?
  11. the little clear hose comin out of the carb and to the bottom of the fram i think its just an overflow... i was wondering if my petcock could be broke or something
  12. hey i just bought my banshee yesterday an road all day an parked it for the nite an i made sure an turned the gas off but when i went to get on it the next day my whole tank of gas leaked out.. anybody had that problem??
