nastyracing
Everything posted by nastyracing
  1. Square plug. Cdi N yes still have red fullbores 425$ shipped in us. Chain sold 1 set of stock intakes sold.
  2. Have the same exact arms as both of u guys. Go blast threw some 4 ft deep whoops w some 3/2 off set wheels and try and stay on straight line not side to side bouncing. Then try same section w 4/1 of set n hold the line w no bounce pull left to right. Ask Ddq what wheels he has.
  3. I will trade ya straight up for the prodesign ones I have for 34/35 mm they just need 2 rubber o ring from pd or Duncan racing for where boost bottle goes in
  4. Stator plate is a stock modded one prolly only get a true +2-3 out of it was on my personal bike for a while. 15$ shipped on that
  5. Prices r not including shipping some stuff I can work w tho just pm me. The billet in takes a pd for 34/35 n want 75$ for . The rubber ones are for stock carbs one sets plugged so no cross over needed.
  6. DEFIENTLY go +1 forward . As far as plus 2 or 3 . Honestly I went plus 3 second time around n wish went plus two. With plus to u want to run 3/2 offset wheel also same as factory offset. +3 u need a 4/1 offset wheel for front end to ride correctly wheels aren't cheap and harder to find then most offsets. 3/2 wheel on +3 rides like dog shit horrible bump steer and bouncing back and forth side to side aka to wide. I'm still waiting to put correct wheel on front my bike have to pick them up. But most say a +3 w 4/1 offset wheel bringing the wheel all the way close to ball joint allows for better turning and less bump steer. Thruthfuly they are the same when correct offset wheel is being used for which ever. Hope this helps.
  7. tm design chain slide 35 tm design lower roller guide 35 sparkle granny smith green pc front hubs 75 pc white clutch cover 75 skid plates 40 rear calipers complete petal to line 75 front calipers30 extended braided lines 45 120 link non oring standard chain new 40 air box w pro flow plate n filter 75 gas tank mint no stripped bolts 45 sprocket hubs 25 brake hubs n rotors 25 stock intakes 20 spindles 45 shifters 15 on off switch 25 graydon bumper 40 coil 25 cdi 50 brake light 20 thumb throttles 25 shift shaft tight 15 piaa head lights baja 50 clutch perchs 15
  8. I picked colors the pearl down side matches my frame. White gator just pimp. Vegas Jeff just nailed it w his design left all trust in him for it as he's the man this whole build I'm going for something different then ne others. Seat was to be the main attention to detail. The rest just clean look plain Jane. Thanks Jeff again.
  9. No I just mounted them up off shit rims to them. But I have another set same shape il bust off bent rims n sell give me a day or two.
  10. i have a great working 01 cdi, and a harness for it it has been gutted drag harness tho . no key switch, no headlight switch, on off ect, all that it needs is a tether switch kill switched hooked into the 2 wires. this is a great working set up off one my personal bikes. 85$ shipped for both. all escentiail plugs are there like coil stuff, stator plugs ect. but all lighting and torrs n bs other stuff has been removed. if you just want cdi 55$ shipped
  11. A properly set up shock for you is the key. Both will ride great. Imo standard travel can ride just as great in same conditions. Where does long travel suspension come into play or when is it a must when you are hitting big jumps catching more then 5ft of air ect, or taking a bunch of flat bottom landings. Standard travel shocks have there limits and at about 5ft and landing no matter how well you have them dialed in or set up they are going to bottom out. If jumping and catching air isn't what you looking to do a nice set of standard travel shocks will blast threw the whoops the same way. Hope it helps.
  12. I have a mint one with no stripped bolts or ripped out tabs. 30$ shipped w gifted paypal payment to getnastyraceing8@yahoo.com
  13. itp t9 reinforced ring rims 8x8 75$ shipped. douglas billet ultimate rolled edge wheels 3/2 offset with a set of fresh 21/7/10 maxis razor tires 150$ plus actual shipping cost price is firm these wheels are not cheap and some of the strongest. i have the lugs that go along with them. figure shipping to be atleast 35$/ + depending where your located. rims are perfectly straight. not bent to hell .choice of wheel of many mx/ xc guys. they can take some abuse.
  14. Thanks sheerider . Yes they in great shape NO stripped bolts and splines on hubs mint.
  15. I have a set of t9 baja reinforced ring rims 8x8 75$ shipped w gifted paypal payment to getnastyraceing8@yahoo.com
  16. 100$ shipped they have chain wack but otherwise mint. Matched set
  17. nastyracing
    Need cases
    100$ shipped I have 2 sets w chain wack... Otherwise mint.
