quadpro26
    2
Everything posted by quadpro26
  1. banshee ign: $240 shipped lightened flywheel stator w/stator plate drag harness coil cdi box
  2. oh i do, just have a couple boost bottles (since they do work better then a cross-over tube) also
  3. i have 2 used polished boost bottles $25 shipped each
  4. You know you can lengthen them out right? There is a spacer inside. So take it apart, catch all the oil (discharge the nitrogen first of coarse). Take the spacer, cut an inch off it and put it together. Recharge it and there you go
  5. I have chain, rear alum brackets, exhaust springs, I can make you the brake lines. 60 fronts, 30 rear. ( New)
  6. prob not a whole lot of bikes that cheap near NJ... you could look in different states and ship it out
  7. i have one, no welded. $50 shipped
  8. mine are big bore, work great on a 4mm $325 shipped
  9. arlo, i have the bigger torchworks radiator. wanna trade? or ill sell mine and buy one of yours. i might need it for a chassis i might be picking up
  10. i know i have the bulbs, ill look for the regulators
  11. this is a 14mm DM ported by eric from WK Racing. twister 14mm billet crank (125 rods) ran 4 races... 12-14 passes (perfect condition exept nose cone. flywheel came loose and divited it. since been filled and sanded with metal filler) ran fine since. $750 DM cylinders, pistons, head w/domes, bolts & nuts, with what gaskets i have $1300 14mm DM cases (welded NOT expoxied) machined and trenched by twister cranks, $350 2-5 over-ride, nuetral down, w/billet 2nd $400
  12. have a gas 350 that runs 4.3's in a stock frame.
  13. aftermarket stator (lil biggerbthen stock), stock cdi, stock cdi, stock wiring harness.... new style cdi, old style stator (plugs were changed)
  14. i actually have new ones, no biggie. i wish the pics worked the same here
  15. have set of 40.5mm mikunis with billet bowls (alky) $500 shipped
  16. set of 40.5mm alky mikuni's with billet bowls w/cable $500 shipped
  17. 3.8's only ran it 3 races so didnt get to tune it much (our races only get 2 practice runs per day) has alot of hp, just never got a chance to put it to the ground. i have a 18 triple that im going to finish with 2 other drag bikes, so dont need this one.
  18. good question, i know it holds the fiberglass riprods and a metal one also.
