DRAG PARTS: 10mm supercub topend (cyl, piston, head w/domes) $800
4mm longrod crank $300
4mm cub topend $900 (cyl, pistons, head w/domes)
7mm cub topend $900 (cyl, pistons, head w.domes)
7mm crank $500
cases set up for 7mm (no chain wack) $250 poilished cases (no wack) $250
Polished billet stator cover $125 polished/cast Direct Drive lockup cover w/waterpump $250 40mm Kehin alky carbs $400 Kehin 34PJ carbs w/cable $200 DMX cylinder (18mm x 85mm bore) ported but not coated $400 18mm crankworks billet crank (big pin/big wheel 133mm rod) $500 custom painted plastics: candy red w/ghost chains and skulls (front, tank, radiator plastics w/cascade grill) $225 alum insert $15 billet handlebar clamp $20 chrome v bars $20 STOCK PARTS:
complete stock ignition $250 (stator, flywheel, harness, coil, cdi, reg) stock tranny $110 sprocket hub $30 brake hub $15 set lower a-arms $65 spindles (old syle) $30set spindles (new style) $40 set set tie-rods (w/ends) $30 radiator $20 complete front brake assy (new style) $50 rear brake lever $25 rear shock $60 rear linkage $20 chrome sm & polished rear linkage $60 foot pegs $20 front hubs w/rotors $30 tank $20 rear 10x9 alum wheels $100 stock rear spring $15 stem mount $5 swingarm sleeve $10 rear brake system polished w/billet rez $125 front shocks $50 cases (w/chain break) $125 cases (w/out chain break pc'd shocker yellow) $200 clutch cover $20
