quadpro26
    2
Everything posted by quadpro26
  1. got a 4mm cub polished, pistons, coolhead w/domes ported by White Knuckle, also have a longrod 4mm crank. Also have these 7mm crank, and 7mm cub ported by K&T w/cases 10mm crank and 10mm cub (not sure who ported it) w/cases
  2. i got enough parts to put together a 4mm cub or a 7mm cub
  3. it can be.... i have cyl, cranks, over-rides, cases, straight cuts, baskets, covers, ect
  4. quadpro26
    Pwk parts
    i have 2 float bowls
  5. i have a cdi for 95 and up $45 shipped 7mm is pretty fresh (low hrs) 4mm is used but good nikel w/new pistons
  6. Ok 4 rotor bolts, pivot bolt and nut $25 shipped
  7. rotor bolt? 4 of them or are you talking about the axle nut? i have all of it.
  8. so front swingarm pivot bolt and the 4 rotor bolts?
  9. Works need seals and recharged (oil leaked but worked great til then
  10. What you looking for. All stock stuff?? All aftermarket (like basket, lockup ect)
  11. I'd rather sell the whole ign., pm's returned I have 2 sets of works, the ones pictured need seals and recharged $100 Other set I have are good. $200
  12. DRAG PARTS: 10mm supercub topend (cyl, piston, head w/domes) $800 4mm longrod crank $300 4mm cub topend $900 (cyl, pistons, head w/domes) 4mm vitos engine (crank, cyl, head w/domes, pistons, cases w/no wack)$1000 7mm crank $500 poilished cases (no wack) $250 40mm kehin alky carbs $400 Kehin 34PJ carbs $200 Hinson basket w/stock ratio straight cuts $375 (stock ratio) straight cuts w/out basket $240 DMX cylinder (18mm x 85mm bore) ported but not coated $400 18mm crankworks billet crank (big pin/big wheel 133mm rod) $500 custom painted plastics: candy red w/ghost chains and skulls (front, tank, radiator plastics w/cascade grill) $225 alum insert $15 billet handlebar clamp $20 chrome v bars $20 STOCK PARTS: complete stock ignition $250 (stator, flywheel, harness, coil, cdi, reg) stock tranny $110 sprocket hub $30 brake hub $15 set lower a-arms $65 spindles (old syle) $30set set tie-rods (w/ends) $30 radiator $20 complete front brake assy (new style) $50 rear brake lever $25 rear shock $60 rear linkage $20 chrome sm link $40 foot pegs $20 front hubs w/rotors $30 tank $20 rear 10x9 alum wheels $100 stock rear spring $15 stem mount $5 swingarm sleeve $10 rear brake system polished w/billet rez $125 cases (w/chain break) $125 cases (w/out chain break) $200 clutch cover $20
  13. got 40mm alky kehins if you want those.
  14. emailed you pics. screwed up the email the first time
  15. Yes, I have a complete ign (no flywheel). $210 shipped
  16. I have a complete polished and chrome rear caliper, plunger, and billet Rez. $130 Billet basket. $100
