Paul M
Paul M last won the day on April 11 2013
Paul M had the most liked content!
2 Followers
Recent Profile Visitors
2,532 profile views
Paul M's Achievements
HQ Soldier
HQ Soldier (2/5)
17
  1. stop and get ur pass at the shell in Westmoreland its on your way , next to the street at the shell station is a water spigot I fill up there , you will need you own hose , try to find a spot on gecko rd , its way better then the washes and not as much dust ! cheapest fuel in the area is usually the red earth casino , Brawley has a Vons and a super walmart . Vons is on the main drag, walmart is out of the way a bit.... on the way out the red earth casino has a bunch dump stations for a quick clean out ............ I go 2-3 times a yr let me know if you have any other Questions
  2. I need out the right for a remote starter , I also have out the lefts I would trade for out the right ...
  3. Like it says I am looking for a set of shear Big bore small flange out the right pipes I
  4. What cc motor is going in this chassis ?
  5. you sure you have a good clean surface where the ground wire mounts ? open up the kill switch and make sure its not corroded and shorting out .
  6. if the air scews dont work I would say plugged pilot jets . clean the carbs ,
  7. mill the head lose the tors advance the timing good flowing air cleaners and then jet for starters ,,,,, you will be amazed at what that dose
  8. Pablo I think you can answer this question better then 99% of the peeps on this site1 lol But i get it, you looking for all input before you pull the trigger .
  9. i ment drop the clip always start with the clip in a rich position
  10. sounds rich ! if you moveD the clip down you made it richer ! try moving the clip up if that dont help , raise the clip and drop the main size and start over untill it gets better . and are you sure they are synced good ?
  11. All the pussies stayed on the porch!! the rest of raced ..............
