kawa110
    51
Everything posted by kawa110
  1. Honda throttle all the way, if you need you can go to the easy carb springs(you should have jacked off with right more often) If you know how to ride a whoop section on a atv you'll know a twisty throttle has no business on atv.....I was in a pinch once and put a thumb throttle on dirtbike(don't ask) huge mistake....lol...I just wanted to ride though
  2. Next time bike is broke, need to lead her on so she will stick around longer
  3. Cuz her bike is fixed, or it was some dude trolling us good
  4. Post ur profile pic so it's bigger, nothing better then hot babe on a banshee...need more pics of babes on banshees.... That would be a good thread to start!!!
  5. I want one also...considered making my own...I got some stainless sheets
  6. ^^^would be nice to drain bowls with the screw on bottom of bowl through the overflow hose like stock, opposed to taking drain nut off and getting fuel on cases.....but I still like the bowls better then stock.....
  7. Love it!!!! Here in Cali the law would have turned on the boy and his parents....
  8. Most likely sat at shop, sat around before shop, with gas in it......clean the carbs...at same time verify the bowls are on correct...put fresh gas..... Let's see pictures of the "lines running to carbs"....most likely added carb drain hoses to make you feel like ther was lots of work done
  9. I'm looking into this^^^^^ Worth every penny?
  10. Damn!!!!!! Knew there was something behind the cliff comment...... Guess your all good now.... Whats the wrist scar look like now?
  11. ^^^^^^agreed.....I like the yellow but not with all the grafiti
  12. Good review!!!! Great find on the shocks--------usefull Info for us cheap asses
  13. All about how you can get the dirt to build up in front of tires to stop... I know nothing....just like riding
  14. ^^^^this I used a 3 jaw and 2 jaw...no luck....and was criticized for it.....I guess the jaw pullers can cause the flywheel to separate thus ruining it(mine didn't seperate or come off the snout)
  15. Like the Popeye cover.... You spray painted the frame?
  16. You race here in Cali? I would like to at least go to a track and try it out....I've only ridden desert trails....
  17. Biggest thing to help with front braking is tires.... Buddy of mine been racing 450 for while now and told me the best thing for his front braking was the tires....he is sponsored by gold speed or something...
  18. Title attached to engine? What's the compression? Leaks?
  19. Do I need the bushing for the throttle? Or can I use the stock? I'm sure I can find a nut also, or can I reuse the stock? Guess I'll find out when I pull it apart
  20. Got PB plate. Need caps, fittings, and cable....
