kawa110
    51
Everything posted by kawa110
  1. Ensure the TORS brain is unplugged. Small Black Box bottom of radiator Sent from my iPhone using Tapatalk
  2. Air filters too much oil Sent from my iPhone using Tapatalk
  3. Heard of older 2 stoke bikes doing it. If it was me I would look to if it has an adjustable timing plate and see where it is set at. Sent from my iPhone using Tapatalk
  4. Engine running backwards? Pull stator cover ensure flywheel is correct and timing is good. I’ve heard of older 2 stroke doing this when the timing is “tight” Sent from my iPhone using Tapatalk
  5. Pretty sure it is, search offer up area code 92285 or 92284 Sent from my iPhone using Tapatalk
  6. Center bearing race shows little “chatter”? Nothing to be concerned with though. Sent from my iPhone using Tapatalk
  7. Interested in some of these Sent from my iPhone using Tapatalk
  8. Straight cut gears? Sent from my iPhone using Tapatalk
  9. Front tires running opposite directions? Sent from my iPhone using Tapatalk
  10. I don’t mind the floats( other then no spring and the price) I hate the red on elka Sent from my iPhone using Tapatalk
  11. I hate to say it! Spray chrome rattle can. Pretty sure your not gunna tear it down for a rechrime or powder coat right now. But I would do some shinty silver before chrome. Just try to hide that patch or atleast keep it from rusting more. Ur engine passed air leak test? Sent from my iPhone using Tapatalk
  12. Right on, passes air leak test now I hope… Let me know when u decide to part with those chrome a arms. Should spray that frame repair silver at the least…. Sent from my iPhone using Tapatalk
  13. Maybe FAST Sent from my iPhone using Tapatalk
  14. Kevin at here highs racing in San Diego can prolly help u. I’ve never dealt with him. He been posting stuff on those big sleeve cylinders lately. Sent from my iPhone using Tapatalk
  15. Trans isn’t under pressure should be fine. Unless case vent is clogged or crank seal is leaking Sent from my iPhone using Tapatalk
  16. He better jump on that offer. Pretty sure Most the active members here would toss that thing. Sent from my iPhone using Tapatalk
  17. Disconnect the tors. Get B8 plugs and ensure carbs are cleans Sent from my iPhone using Tapatalk
  18. What size rear tires u run? Can u measure the distance from ground to lowest part of link? I’m setting my bike up for desert racing and do not want to lose ground clearance if I decide to get the elka link. I’m allready bashing the stock link on rocks. I have a -1.5 fireball arm. Sent from my iPhone using Tapatalk
  19. What length is ur arm? -2? How much ground clearance do you lose with the elka link vs stock link? Sent from my iPhone using Tapatalk
  20. Full of rust water doesn’t sound good. If you feel that the stator and flywheel are still good just clean rust from off the pickup contacts. But just replace with oem. Sent from my iPhone using Tapatalk
  21. Naw. Typo. Call them up. Sent from my iPhone using Tapatalk
  22. Yes. Call me up and ask for Evan. Have ur card ready. Ordered my steering stem on Monday. Sent from my iPhone using Tapatalk
  23. So I have idle adjustment screws? Sent from my iPhone using Tapatalk
  24. Purchase the motion pro tors elimination throttle Cable kit. New cable, adjusters, and caps. Sent from my iPhone using Tapatalk
