kawa110
    51
Everything posted by kawa110
  1. Replied Sent from my iPhone using Tapatalk
  2. Prices include shipping to the 48, gifted or add fees via PayPal. Share with your Facebook freinds. Cut airbox, all clips, lid not cut. 40$ Lockup-cover with new alloy bolts kits hardware in pakage 180$ Oem Cylinders, dune port. One needs sleeved. 50$ Brand new a arm bushings 17$ Shock linkage 20$ Coolant bottle holder 13.50$ Aftermarket Polished axle nut 25$ JDS customs under tank mount 25$ Intakes, no cracking, carbon fiber reeds in great shape, new alloy bolts hardware in package. 40$ Modified stock timing plate 15$ Aftermarket axle nut 15$ Billet thumb lever 15$ Exhaust clamps 25$ Stock clutch cover 25$ Sent from my iPhone using Tapatalk
  3. Bump! 350$ with LS carrier and brake stay with clip, shipped to the 48 PayPal gifted. Chrome, roll design, -2, new pivot bearings. Zerk for pivot tube. Sent from my iPhone using Tapatalk
  4. Couldn’t one just modify the stock silencers to fit aftermarket pipes. Don’t the silencers have the spark arrestor stamping so if you get stopped show them the stamps on stock silencers. Sent from my iPhone using Tapatalk
  5. My fireball arms use 19 1/4 Sent from my iPhone using Tapatalk
  6. Made valves tick Sent from my iPhone using Tapatalk
  7. I got a pretty rough shape stock cover, that Does NOT leak. 20$ PayPal gifted to me and I’ll send it your way on Monday. I can get you pics late tonight or tommarow. Sent from my iPhone using Tapatalk
  8. What is the bore on the actual oem set? Stock? No porting? Sent from my iPhone using Tapatalk
  9. ^betterthen elephant snot(rtv) Sent from my iPhone using Tapatalk
  10. Order some 1211 or yamabond. Sent from my iPhone using Tapatalk
  11. To lean will gap plugs faster then normal. Sent from my iPhone using Tapatalk
  12. You will need to remove the engine and split cases to replace crank seals. Sent from my iPhone using Tapatalk
  13. Pressure test the engine? Ensure carb caps are tight. Sent from my iPhone using Tapatalk
  14. Fuck that head, buy a cool head. Don’t overbore, only bore it to the next size required. Sent from my iPhone using Tapatalk
  15. ^^^for another few hundred $ hand coned LED’s the way to go??? Sent from my iPhone using Tapatalk
  16. If he not interested I am^^^^^ Sent from my iPhone using Tapatalk
  17. You will not get a accurate reading with “bad” reeds. Throttle open to allow Maximum amount of air into cylinder to compress. Sent from my iPhone using Tapatalk
  18. Cylinders ported or virgin? Oem cylinders? Sent from my iPhone using Tapatalk
  19. Did u get them in PCs and weld together or they were allready assembled? Sent from my iPhone using Tapatalk
  20. Call a lien sale place. Sent from my iPhone using Tapatalk
  21. Thnx Consider sold Sent from my iPhone using Tapatalk
  22. I’ll take theze. Pm me ur PayPal Sent from my iPhone using Tapatalk
  23. I’m looking for gold fronts. Prefer without the rolled bead edge Sent from my iPhone using Tapatalk
