kawa110
    51
Everything posted by kawa110
  1. Sold Sent from my iPhone using Tapatalk
  2. Sold Sent from my iPhone using Tapatalk
  3. Need motor mods and elevation. Check the jetting forum... May already be listed on what you need. Sent from my iPhone using Tapatalk
  4. Rear shock, linkage and hardware(need one zerk) 125$ shipped to the 48. PayPal, buyer covers fees. Sent from my iPhone using Tapatalk
  5. Stock arms Good ball joints, One needs thread repair No dents Good bushings 125$ shipped to the 48 PayPal, buy covers fees.
  6. K&n style air filters for 28mm carbs with outerwears Never used. 100$ firm, shipped to the 48. PayPal, buyer covers fees. Sent from my iPhone using Tapatalk
  7. Tapatalk for pics. Sent from my iPhone using Tapatalk
  8. You need to start with a leak down test. Sent from my iPhone using Tapatalk
  9. Benefit of the wampum is if you want a stock look. Sent from my iPhone using Tapatalk
  10. I’m at 44, Sent from my iPhone using Tapatalk
  11. Still looking, wanted stock or aftermarket rear brake hub.... Sent from my iPhone using Tapatalk
  12. Raw snipers Sent from my iPhone using Tapatalk
  13. U can find stock motors usually dirty or unknown hours for around 1000 Cases are usually 200-400 alone Look on Facebook Sent from my iPhone using Tapatalk
  14. Start bike, spray around intakes with carb cleaner, if idle climbs your intakes have a air leak Sent from my iPhone using Tapatalk
  15. Try slp I’m replacing fmf with srp Sent from my iPhone using Tapatalk
  16. Are the a arms beat up? Sent from my iPhone using Tapatalk
  17. Banshees don’t have camshafts. Do you mean crank? All these items stock? Post pics Mint oem stuff is sought after sometimes. Leaking radiator is trash. Sent from my iPhone using Tapatalk
  18. With the bike cold. Remove radiator cap. If the leval is low your prolly losing it. Start bike with the cap off of the water is bubbling you have a leak. You can maybe rent a coolant pressure tester.... Sent from my iPhone using Tapatalk
  19. Milky dark.... You need to ensure your coolant fluid isn’t mixing in with your trans oil. pressure test the coolant system. Might have bad o ring on the coolant tube coming out of cover going between carbs. Or. Worse a blown head gasket. Sent from my iPhone using Tapatalk
  20. Replace the fuel valve needles, or float valve needle. U Can attempt to clean up the fuel valve needle seats or replace these as well. The needles have a rubber tip that can be damaged or “worn” over time. The seat is brass and can become damaged as well. Sent from my iPhone using Tapatalk
  21. Sent from my iPhone using Tapatalk
  22. How much weight do most take off? I really don’t know? It helps in “reving” quicker? What does it do? I have a lightened flywheel that came with a motor I was told built by hytechracing in Riverside California. Maybe he can shave one for you. Duncan racing charges 90$ I don’t know how much they take off though. Sent from my iPhone using Tapatalk
  23. Order the 18mm from amazon? Sent from my iPhone using Tapatalk
