kawa110
    51
Everything posted by kawa110
  1. Replaced with oem carbs? Do the floats float? Remove from carb and put in water. Make sure they are not retaining fuel and causing them from floating. Older brass floats will get pinholes in them or collapse. Not common with plastic floats though.
  2. I have stock cylinders 60$ shipped to the 48 one cylinder needs sleeved
  3. Got a shee with Duncan mid range motor. seller told me to run 50/50 race gas and 91. bike set up for glamis. called Duncan and I was told to run 110 or higher, not mix. I asked about going +4 on timing and was told with ther port job that it’s not necessary. 1. should I go +4? Got a adjustable plate and a lightened flywheel(not installed yet) 2. race gas or mix? 3. Duncan’s “instructions” for the mid range motor is too run b9es plugs, I have always ran b8es. Why b9?
  4. Recommendations on length? Ive heard the +2 lines are long enough for for +3 arms. or will streamline know? thnx
  5. This topic came at the right time.... I need front lines for +3 fireball a arms and a line for the -2 swingarm. Recommendations?
  6. Did you soak the plates before install. I had a clutch do same thing. Toasted. is the basket grooved? Time for new maybe.
  7. 80$ on a grey hound from Cali to Virginia. Still for sale. Wrapped up and ready for a ride.
  8. Looking for black or white rad cover. Have red to trade.
  9. Hard to find frame guards. Thers some carbon fiber ones be easier to find Sent from my iPhone using Tapatalk
  10. Is that a hole? or the chrome peeling? If it’s just peeling you can clean it up, paint it so it doesn’t promote rust and find some frame guards. Sent from my iPhone using Tapatalk
  11. Looks like it’s cleaning up real nice! Sent from my iPhone using Tapatalk
  12. Got some stockers, one needs sleeved. 50$ shipped Sent from my iPhone using Tapatalk
  13. Floridians a convicts seem to know the most about the subject. Sent from my iPhone using Tapatalk
  14. A tight hole is still a hole. Sent from my iPhone using Tapatalk
