LaegerEliminator
    27
Everything posted by LaegerEliminator
  1. I would guess that mine gets run about as hard as a guy can imagine with my setup and my style of riding, but I will give it an inspection when the time comes. Mine is a spring loaded with a Duncan 7 plate setup. They were not producing the 8 plates any more when I bought mine in 2008. I see on the Hinson site that they show them as currently being available.
  2. I have about 90-100 hrs on my Hinson Billetproof basket with straight cut gears and have had not issues with it so far. Most of my riding is mx type or aggressive duning.
  3. 06' YFZ caliper on my Laeger Pro-trax front end with Laegers wave rotor. Sent from my DROID RAZR using Tapatalk
  4. My Laeger pro-trax front end uses larger diameter wave rotors than OEM. Plus I run YFZ dual piston front calipers and braided brake lines. With my setup the caliper is moved further away from the spindle so the clearance with 4-1 wheels is close. The stopping power over a stock Banshee and pretty much every other bike I have ridden is night and day better and stronger. I can use a single finger on the brake lever and have effortless control on high speed slow downs. It will do stoppies easily too if you have enough front wheel traction. Sent from my DROID RAZR using Tapatalk
  5. I'm pretty darn sure that grab bar is bent up from its original intended shape and angle. It looks like it is either a PRM or an AC. I have an AC on mine that looks the same. My AC has a very slight bend in it due to a couple of quick and steep wheelies, and it isn't bent anywhere near as much as yours is... Am i seeing little roller wheels attached to the grab bar too?!?!
  6. Looks for sure like the rear grab bar is bent up. Maybe from a few hard wheelies... Sent from my DROID RAZR using Tapatalk
  7. Pics uman! Sent from my DROID RAZR using Tapatalk
  8. ^^^ I could only dream of mine lasting that long Sent from my DROID RAZR using Tapatalk
  9. 35-45 minutes of hard riding and I will burn through a full tank of VP C12
  10. Call Duncan direct. Talk to Leonard. They should still have them. Sent from my DROID RAZR using Tapatalk
  11. Just keeping ya in check! Sent from my DROID RAZR using Tapatalk
  12. 12-4 central is not the same as 2-6AM Eastern... That's my Mountain time. 10-2 wouldn't be Pacific either... Sent from my DROID RAZR using Tapatalk
  13. David, what's your height and current weight? How many pounds of muscle do you figure you have put on since starting to train consistently?
  14. TM Design works all the way Sent from my DROID RAZR using Tapatalk
  15. Spend the money, you won't regret it. Sent from my DROID RAZR using Tapatalk
  16. Good to hear you doing OK Matt. Well wishes, and prayers to you and your family while you slay this beast. Thanks for the transparent update. Sent from my DROID RAZR using Tapatalk
  17. I run the T.M. Designworks also and am very happy with it. I'm pretty sure 15 tooth is the max size out of the box, but you can very easily enlarge it to run a bigger sprocket. I run a 16 tooth with mine. I took my air die grinder with a cutting drum tip and carefully worked my way back and forth to evenly enlarge it. Didn't take very long and didn't take a whole lot of effort. I'm pretty sure you could enlarge it to a 17 tooth without compromising the integrity of it. Sent from my DROID RAZR using Tapatalk 2
  18. I purchased a set for my build and I am very happy with them. I have a Laegers Pro Trax chassis with PTR High Rev Pipes. I originally tried to use OEM style hangers, but they wouldn't fit right. Things don't fit exactly the same on my chassis as they do on an OEM chassis. I found the adjustable TM unit worked perfectly for me and they have held up well. Sent from my DROID RAZR using Tapatalk 2
  19. Who is Lew Jr. ? Looks like one of Dean Sundahl's creations....? Looks pretty sweet! Sent from my DROID RAZR using Tapatalk 2
  20. What is your motor setup? Sent from my DROID RAZR using Tapatalk 2
  21. Very nice bike you have there! I built my Laegers Pro trax Banshee in 2008. Huge improvements over a stock chassis. Love it! Sent from my DROID RAZR using Tapatalk 2
  22. The first time I saw him post one of his wild ideas/suggestions I tried to give him the benefit of the doubt and see it through before getting too judgmental. He seemed to start off with an OK idea, but then quickly veered waaay off into left field... I have watched him do that same thing several times. Once he starts heading for left field he just keeps going and going and going... He must be mixing medications or something... That last go round on FB was pretty good entertainment.
  23. I must have missed that part. There was way too bable going on for me to read all the details... I just skimmed it and was laughing out loud most of the time. Sent from my DROID RAZR using Tapatalk 2
