terr1bleone
    chicago
terr1bleone's Achievements
  1. may spend more for the right pipes if any come up soon... looking to ride inframe or outframe shearer or cpi small flange small or big bore.
  2. looking for silenced outframe same side stacked shearer or cpi pipes. just seeing if anyone has anything out there before I just go with inframe shearers.. have about $300 to spend, thanks.
  3. a lot of people are saying now its not so great plus id need extra links im running a +8 arm.. looks like my only option seems like a 530 setup.
  4. the last one I had was an RK before that an EK 520SRX, the other ones I had gotten the strongest the dealership had but I don't remember the brand. They usually pull themselves apart in one launch or second gear hit. Heres a pic of a streched part, theres quite a few links like that even one broken one. It was oiled up at the time, just been sitting in my garage corner for a while. Uploaded with ImageShack.us
  5. Cool, do you run O ring or non? Ive only crushed one front sproket, but ive been through 4 chains.
  6. for real, my banshee made around 95/55.. so thats good to hear your yfz is holding up.
  7. I didn't read every response.. but loco, does the 530 chain help that much? ive been snapping 520's left and right, but I didnt think stepping up to a 530 would help much since they are all rated on tensile strength anyways and i could get a 520 in the same strenght. Have you ever checked into Ti parts? I was thinkin about ordering custom 38/17 Ti sprokets/chain from sidewinder. Anyone have experience with them?
  8. I have a 90hp+ shee with stock suspension, but I only use it for straight line.. I use a yfz for jumping.
  9. I smoke modded banshees all the time on my basicly stock yfz, It just rides easier. Its all about the rider when they are both lightly modded. Praticice launching try to get it to hook up, possibly launch in 2nd and slip the clutch, the banshee should be faster though.
  10. I sold an old engine that needed a topend on ebay for 350 a not to long ago if that helps.
  11. Im going with a 25x12x9 Titan Trail Claw 2, I found a local shop that has them in old stock. Ill be picking them up tonight, Im hoping with the lower profile they only measure out to 23''. Thanks to those who responded. Hopefully it works out.
  12. I was talking about the popular size 22x12x10. Ive thought about bigger realtor's or vamp's but I think 25'' is the lowest like you said you run 26''. Im not sure i have enough torque to pull that big of a tire. Im more looking for the 22-23'' range when inflated to a couple psi. I haven't been to any races yet still gettin the bike sorted out. Ive ridden lakes in the past, It hasnt been too cold this year though didn't think that was going on.
  13. dajogejr- I know ill never deadhook, but im just trying to make it better then feeling like riding on ice. Loco- Thanks, ill check those out. I was also thinking about cut knarlys in 22''? Ive seen you run them hows the wear? or are they only good for grass/softer dirt.
  14. realators and vampires are too small, they only measure out to 19.5. I heard pro wedges were only good till about 60hp.. I have a little over 90.
