mofoka
Contact Methods
  • Website URL
    http://www.myspace.com/nocturnaldesign
  • ICQ
  • Yahoo
    mofoka
    Calgary, AB Canada
  • Interests
    usernames
    360 mofoka79
    PS3 mofoka
    fatty
Recent Profile Visitors
4,002 profile views
mofoka's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. For sure I'd deal with him again!
  2. That PRM z-plate looks nice I have a solid aluminum plade that only goes half way, similar to JD's just not as pretty. It made a huge difference getting over the ruts. Just slide over compared to the stock anchor getting hung up
  3. after jetting it made a huge difference engine ice probably dropped another 10 deg or so I agree keep the rad clean. I haven't over heated since, even creeping through the slow stuff. Mind you I do ride in Canada...
  4. i've got 23 razrs up front and 22 bear claws for the real soupy trails and 22 xc holeshots for more dry mixed trails. I like the clearance and my rims are offset so I don't find it tippy at all. I think if I needed to buy new tires I would go for the razr2 or try out the Kenda Kutter XC. In the rocky woody crap I ride in I'd rather they be tough than light.
  5. Good to know. yeah it's the graphite wheel paint I just picked up some gloss black to touch up the calipers and rotors so i hope they turn out as well as the wheels
  6. Figured I'd share some paint results. Lord knows my bansh would love some attention but the gsxr's first this time. I used an etching primer and duplicolor's 'granite' rim acrylic enamel. Two lessons learned 1- I used two cans and it did well but i would have liked another can to lay another wetcoat. 2- I should have used a respirator (I thought about it but not bright enough to buy it) Prepped My ghetto booth after primer and done
  7. ok i'll send you a PM when i'm set to go. I've got to drop a few bills on my bike first. Tnx again fort he info
  8. Just checked out your web page. 85 for a re-valve and 40 for a new seal. Sounds good Would you recommend a new/stiffer spring? I got this shock off a member and it squats damn low. Or would a rebuild with some valve work do it? I'm about 200 on a stock swingarm on racetech's website their calculator says Recommended Rear Spring Rate: 7.13 kg/mm .... seems like a big difference thanks for advice
  9. Pulled to make a local deal for some gold valves... please delete ad
  10. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=320649437942&viewitem=&sspagename=STRK%3AMESELX%3AIT i'm going to try my hand at selling with ebay... here is the first listing
  11. You might be SOL if you want to run your fullbore. The clarke one is sexy shit. I had the 5.7 ims and didn't like it because I couldn't run my CR low bend bars. But most trips I make it back with a little slop in the bucket, so I pitched it.
  12. I heard they are italian chains.(no experience there) I'd try them but I've always had great luck with RK and DID. For the price i'll probably stick with them.
