dirtydownunder
    2
Everything posted by dirtydownunder
  1. should send it out n get it, trued and welded. give it a lil birthday.
  2. only been hearing how much of a piece of shit it is. iphone people are weird haha.
  3. hes around, just been playing with his cars. i know when im playing with my cars, banshee stuff kinda is less important.
  4. after ive tensioned the head down, after the first warm up. i rip on it good. never let it idle for to long after a rebuild, keep ninging it or ride it. dont change oil ratio's just for run in. do heat cycles if you want, i think theyre silly.
  5. 2010/11 and 12 where the same colour scheme. gonna cost ya around 10g's. then you will have to mod it, coz stock banshee's suck, so youll be in a total of around 13-15k. pure waste of money, when you can buy a used banshee and spend 5-8k on it, it will be awesome.
  6. dam that sucks, i feel bad for bonnar, he gonna get dropped. if he wins, fukn awesome. i just dont see it happening.
  7. i tried them, no other changes to the bike besides vf3 to vf4 reeds. and i went to climb a dune and instead of going up it, i went straight threw the fucking middle, out the other side. these work !.
  8. hmmm i did it ages ago so i cant really remember heights, i think they were about 4-6mm high ? 1/4" ish i just cut a bolt down, and hacksaw cut a slit in the top for a flat blade screwdriver.
  9. how do the plugs look ?, pilots should be ok, im running 50's. but you being higher up could need maybe 42-45 pilots. have you tried new plugs with the 270's ? from 330 to 270 should be a big difference. try some 260's. but check the plugs, make sure it isnt too lean. pull the needles out, see where they are at. the needle should be a 5FP-17. what are your air screws at ? have you checked pick up gap and resistance, and checked coil ?
  10. I made lil threaded spaces up to screw into the cylinder, so the studs had something to bottom out on.
  11. check plug caps and leads, etc as well. just incase you have two probs.
  12. just a gasket sealing compound spray. you can get it in a tube or a spray can. i use the spray.
  13. i spray my base gaskets with hylomar spray. throw a straight edge on it, and see if its bowed at all.
  14. Both great. I been using wildcard lately, awesome peeps.
  15. If they stuck, you'll have to remove Al nuts, and try to lift the head up and undo them 2 stuck studs at the same time. Without damaging the head or cylinder.
  16. You're correct with the 5 10 15 20. But if you have two turning and not tightening, you have to remove them and see what's stripped. Also you tighten from the centre and work out.
  17. UFC 151 CANCELLED WTF !!!!!!
  18. try some 280's and work down. get some 250, 260,270 and 280 jets. on the servals, id back the timing down to stock. especially if you dont know what size domes they are. do a comp test, see where youre at.
  19. the roo is a good daily, i just thought the banshee would be fun on weekends.
  20. engine ? my banshee doesnt run, whats an engine got to do with it ?
