pittss1c
    Central Il
    I am told...Hot Rods 4mil stroker 5mil long rod crank with Hot Rods pistons, noss cool head w/21cc stroker domes, cylinders have a mild port job. V Force 2 reeds, 28mm PWK carbs, DG Nerf Bars, DG Full Skid Plate, DG pipes, Durablue axle, newer YFZ450 tires and wheels, dual carb mounted air filters
pittss1c's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. Hello from champaign/Urbana. I also head to Taylorville from time to time as well. For camping or laid back riding LTM is the best in the area, for a hard day of riding, I go to badlands.
  2. I have PWK 28s on a 4 mil. When doing a plug chop, if I go through all gears and hold it for a bit in the top gear for a few seconds, it will show lean 100% of the time. No matter how big my jets are (even way too rich) I am guessing that means the bowls can run dry on long runs.
  3. I have them on stock A arms. I am told I will die soon though. So does another guy I met that has run them on stock arms for the last few years. I am guessing they will eventually ruin the ball joints, but I hope to upgrade the arms by then.
  4. Ready to install my topend
  5. Very Profound. I did not know this about Willy Nelson. Whether or not you are a country music fan, these are truly the words of a deep thinker, and a highly intelligent person. So simple, yet so profound! Read the words of wisdom from that famous philosopher Willie Nelson, iconic country and western singer, on his 75th birthday below his esteemed portrait below. Only a man with such wisdom and maturity could be so concise and succinct in phrasing his feelings at this turning point in his life. Read below and digest carefully. "I have outlived my pecker".
  6. I'll be there with a blaster (Banshee cylinders are still at F.A.S.T.) and am deciding if I should bring a bike too. Are most people getting track passes as well?
  7. Stupid rain! Hopefully the woods won't be too wet.
  8. No banshee for the weekend... But I put a new topend in the Blaster last night, and have a babysitter lined up. I should have the motor broken in by the weekend.
  9. I love you video sig.... I almost peed myself. I am crossing my fingers on the banshee, we will see what they say... I am going to try to get a new piston in the blaster in case I am going to bring it. (that should be pretty simple, there is no damage there)
  10. I'm trying hard to make it. My cylinders are off to the shop, but it turns out my wife will be out of town. I might have a babysitter lined up, but am not sure how early I can arrive. If the weather is right, I can't see missing another one of these.
  11. I would also get it apart and check for play in the bolt holes. (out of round)
  12. Good luck with that jugriggs! (Though I don't have too much better track record)
  13. I need to get my cyls out to get bored so I can make it in time! Either way, I will plan to come (even if I have to bring the blasty)
