uwenr
About uwenr
  • Birthday 09/20/1973
Contact Methods
  • Website URL
    http://www.myspace.com/lilwenr
  • ICQ
  • Yahoo
    uwenr
    Glendale AZ
    7 mil billet crank stock cylinders milled & chambered stock head 2-5 override 39mm Keihin on alky DD lockout CPI BB OOF drag pipes Lightened stock frame +12 ladder style swingarm 12 paddle sls haulers 350 mild port 39mm Keihin on alky +8 oval tube swingarm 10 paddle sls haulers 2008 RZR
Recent Profile Visitors
2,982 profile views
uwenr's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. updated list please text 602-478-5307 CPI BIG BORE SMALL FLANGE BOTH OUT LEFT BLACK $325 DOUBLE BUFF MOHAWKS 10X5 DOUGLAS BLUE LABEL $125 CHROME CLUTCH COVER WITH BILLET INSERTS AND DIPSTICK $150 CDI/REGULATOR WITH HARNESS, HARNESS IS HARD WIRED FOR NO KEY, NO KILL SWITCH, AND NO LIGHT SWICTH. $75 COIL $50 SEAT $50 PLASTICS BLACK, FRONT, REAR, TANK COVER ALL DRAG CUT $50 BILLET BAR CLAMP $20 REAR BRAKE CALIPER WITH BILLET BLOCK OFF $30 TANK WITH DUAL PINGEL AND BILLET CAP $100 RADIATOR WITH HOSES $40 SPINDLES DRAG CUT, NO FRONT BRAKE SET UP $40 REAR HUBS $30 STOCK CHROME SPROCKET HUB $30 STOCK FRONT SHOCKS WITH CHROME SPRINGS $65 STOCK TRANNY WITH DRUM $75
  2. i appreciate all the good responses, it was good dealing with everyone. I try to be as fair as possible with pricing and description.
  3. Updated list before i put the rest on ebay CPI BIG BORE SMALL FLANGE BOTH OUT LEFT BLACK $350 FRONT A ARMS STOCK CHROME $250 DOUBLE BUFF MOHAWKS 10X5 DOUGLAS BLUE LABEL $125 CHROME CLUTCH COVER WITH BILLET INSERTS AND DIPSTICK $175 2 THRU 5 OVERRIDE $300 CDI/REGULATOR WITH HARNESS, HARNESS IS HARD WIRED FOR NO KEY, NO KILL SWITCH, OR NO LIGHT SWICTH. $75 COIL $50 SEAT $50 PLASTICS BLACK 2 SETS $50 EACH BILLET BAR CLAMP $20 LONESTAR AXLE STOCK SIZE NOT BILLET $100 REAR BRAKE CALIPER WITH BILLET BLOCK OFF $40 TANK WITH DUAL PINGEL AND BILLET CAP $100 RADIATOR WITH HOSES $40 SPINDLES DRAG CUT, NO FRONT BRAKE SET UP $40 REAR HUBS $30 STOCK CHROME SPROCKET HUB $30 STOCK FRONT SHOCKS WITH CHROME SPRINGS $65 STOCK TRANNY WITH DRUM $75
  4. Revised list and link to pics http://s253.photobucket.com/albums/hh67/uwenr/banshee%20parts/ CPI BIG BORE SMALL FLANGE BOTH OUT LEFT BLACK $350 FRONT A ARMS STOCK CHROME $250 DOUBLE BUFF MOHAWKS 10X5 DOUGLAS BLUE LABEL $150 CHROME CLUTCH COVER WITH BILLET INSERTS AND DIPSTICK $200 2 THRU 5 OVERRIDE $300 CDI/REGULATOR WITH HARNESS, HARNESS IS HARD WIRED FOR NO KEY, NO KILL SWITCH, OR NO LIGHT SWICTH. $75 COIL $50 SEAT $60 PLASTICS BLACK 2 SETS $50 EACH BILLET BAR CLAMP $20 LONESTAR AXLE $100 REAR BRAKE CALIPER $40 TANK WITH DUAL PINGEL AND BILLET CAP $100 38mm PJ CARBS CONVERTED TO ALKY $350 RADIATOR WITH HOSES $40 SPINDLES DRAG CUT, NO FRONT BRAKE SET UP $40 REAR HUBS $40 BRAKE PEDAL CHROME WITH CHROME SPRING $30 38mm BOSS SEPARATE INTAKES $75 MARVIN SHAW FRONTS $150 STOCK CHROME SPROCKET HUB $40 STOCK FRONT SHOCKS WITH CHROME SPRINGS $75 STOCK TRANNY WITH DRUM $75
  5. picture link to my photobucket http://s253.photobucket.com/albums/hh67/uwenr/banshee%20parts/ SOLD stator cover kicker shifter 4mm crank milled head small bore cpi
  6. i will take pics tonight and dump them into photobucket and post the link. Too hard to post that many pics.
  7. prices are OBO, I live in Phoenix so shipping is not included. Text 602-478-5307 or PM will consider some trades, looking for HS plastics, Shearer big bore small flange out one side CPI SMALL BORE RAW BOTH OUT THE LEFT $350 CPI BIG BORE SMALL FLANGE BOTH OUT LEFT BLACK $350 FRONT A ARMS STOCK CHROME $250 DOUBLE BUFF MOHAWKS 10X5 DOUGLAS BLUE LABEL $150 9 PADDLE DOUBLE BUFF HAULERS $150 +8 METAL TECH OVAL TUBE SWING ARM CHROME W/ CARRIER & LINKAGE $350 CHROME CLUTCH COVER WITH BILLET INSERTS AND DIPSTICK $200 BILLET STATOR COVER $80 2 THRU 5 OVERRIDE $300 CDI/REGULATOR WITH HARNESS, HARNESS IS HARD WIRED FOR NO KEY, NO KILL SWITCH, OR NO LIGHT SWICTH. $75 COIL $50 SEAT $60 BILLET SHIFTER $15 PLASTICS BLACK 2 SETS $50 EACH BILLET BAR CLAMP $20 LONESTAR AXLE $100 REAR BRAKE CALIPER $40 CHROME KICKER $20 TANK WITH DUAL PINGEL AND BILLET CAP $100 4 MIL CRANK WITH STANDARD RODS $200 MILLED HEAD WITH CASCADE SMOOTH AND POLISH $75 38mm PJ CARBS CONVERTED TO ALKY $350 RADIATOR WITH HOSES $40 SPINDLES DRAG CUT, NO FRONT BRAKE SET UP $40 FRONT HUBS DRAG CUT CHROME $40 REAR HUBS $40 BRAKE PEDAL CHROME WITH CHROME SPRING $30 38mm BOSS SEPARATE INTAKES $75 MARVIN SHAW FRONTS $150 MARVIN SHAW REAR $150
  8. i three stock springs and 3 hd springs. Also different disks, i think they are for a R6.
  9. it has to be a 05 or newer blaster, the hubs are not the same on the older blasters.
  10. Would you be willing to part with one set of the paddles with or without wheels?
